Exactly what it says
Im building a 97 RS4 and i need all the time RWD with a manual dogbox
Basically
can i use an R33 RB25 RWD tranny? will the driveshaft work? do i need the manual driveshaft from the r33?
:sorcerer:
many thanks!
https://www.sau.com.au/forums/topic/155173-permanant-rear-wheel-drive/
i cant find one around me for the right price
Im paying 3,000 USD for a fully loaded dual sunroof stagea (im having kids, the solid engine moune 12k/10k spring sileighty isnt gonna cut it)
but i dont want to give up drifting. and i have a few grand to be able to do the mods i need (suspension, manual, wheels)
plus it has almost 2 full years of SHaken-sho
Edited by yokotas13
rb25 rwd box has different tailshaft as the rwd is a yoke that slides in the back of the box and the 4wd has a plate that bolts onto the back of the transfer case, just rip the front driveshaft off the 4wd box and its rwd (still leave all 4wd sump, front axles, etc )
im unsure if the gtst tailshaft will be the correct length, but u will need it for the gtst 5 speed box if u go that option, and maybe have shaft lengthened or whatever it needs to fit.
Edited by CruiseLiner
so it wont damage my transmission at all just not running the front driveshafts?
In that case ill just get an R33 GTS4 or GTR mission
nope it wont damage nothing running it without the front driveshaft :laugh:
im talking the single front driveshaft that goes from the tf case to the front diff, not the axles going to each wheel, they can stay as per normal 4wd operation :huh:
4 bolts and the driveshaft slides out the tf case and the hole in the tf case is even sealed so u dont have to plug it up.
happy drifting :(
but the problem is the tranny to use
DOes anyone know if i can use a RWD transmission with slight modification (or know someone that has)
since we have established i can use a GTS4 or GTR transmission and leave the front driveshaft unhooked.
im just looking at all my options, it is easier to source a rwd tranny than an AWD
awd tranny is cheaper and easier :(
gtr boxes with tf case are about $800-$1000 and heaps of them around and gtst go for like $1500+ and rare as everyone wants them
Where have you seen GTR Boxes for $800? Before I bought mine from Jap auctions I was quoted $2000 for a GTR box.
on the forums and i got mine from a guy in perth for $800 i think from memory (2 years ago now)
seriously $2000 is stupidly expensive.
i wouldnt pay over $1000 for one
heres some links to ones for sale i found on a search on yahoo.com
http://www.boostcruising.com/forums/index....howtopic=183675 - $750
http://www.skylinesaustralia.com/forums/in...howtopic=139317 $1200 ono
http://www.skylinesaustralia.com/forums/in...;hl=gtr+gearbox $1200
http://www.skylinesaustralia.com/forums/in...=153805&hl= $1000
http://www.skylinesaustralia.com/forums/in...=137431&hl= $500
http://www.skylinesaustralia.com/forums/in...=147956&hl= $800
thats after a 5 min search :laugh:
I had the option of 3 GTR boxes when I bought mine
R32 GTS4 $350 (not as strong as a gtr box)
R32 GTR $500
R33 GTR $800 and only 46k's, so I bought this one
There are a few guy's on this forum with RWD models, maybe they could post up some pic's of the underside of their car for you, so you can get a idea
Aren't Stagea's the same length as a r33 in wheel base? That way the r33 GTST tail shaft will fit?
Where are you located Japan?
around me im looking at 600-800 for a r33 gtr box, and a few hundred less for a r32.
Im really worrid about the RWD setup.
I was thinking the same with eh R33 GTST driveshaft..it SHOULD be the same length.
And now i have to worry about a diff as well
this is a headache
This Stagea is being built for drift, AWD will never be used anwyays
I am in the Kanto plane of japan. By tachikawa
Edited by yokotas13
well the wife said that i have to get something more family friendly
solid engine mounts and 300 HP isnt really family friendly...plus you have to have an interior for that also lol
i pan on continuing my drifting with the stagea
I have already sourced all the items i need mostly,
going with a 14k/12k suspension setup.
Nismo 2 way diff
and once i get this whole tranny figured out i will be doing that as well
i have about 3700 USD to play with for mods. so it sohuld be fun.
Edited by yokotas13
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
