I have had a Cefiro and an R32 (2 door) but a mate has an R32 4 door.
Cefiro is a bit bigger and a lot of people really like the shape. their steering feels more lke a S13 than an R32 and they look awsome when modded. they have the same engine and box but there are a few differences
all the plugs on the cefiro loom are different to R32. different AFM, different cams and different ECU.
The cefiro makes more torque low down and the skyline ,makes more power up top in standard from but once you mod them they will be exactly the same.
cefiro has more interior room but less sporty interior.
it all comes down to what is available when you are ready to buy, I would have to say a kitted cefiro looks better than a R324door
there are more parts available for R32's but it is still easy to get bits for cefiros.
I am going to get flamed for this but the cefiro drifts better than a r324door and attracts less police attention and the insurance on them is less.
My 2c
This is one time where you should just go with what you think looks better.. Coilovers and other suspesion bits should be easier to find for Cefiro, and with slightly better prices than 32 bits if you look around. Good panels can command fairly high prices.
32's double wishbone front end geometry is said to change less under load(I.e drifting). GTR guards are a handy way to widen a four door 32.
Both are great cars. Just make sure you get a manual.
If I have a chance, I will select either R32 2 doors or Cefiro.
If you would like sporty looks, go for R32 2 doors. Otherwise Cefiro.
There're too many R32 2doors and 4 doors on the street.
Cefiro doesn't looks good unless they have a wild body kit. The one in D1 drifting.......forgot how does it called the body kit.
I don't personally like the tail light of the R32 4 doors, and the length of the car........don't too sure how's the actual length between 2 and 4 doors, but 4 doors looks a bit longer.
I heard it's only 40mm longer, but it always looks more than that so I looked it up:
GTS-T Type M Coupe Exterior dimensions (LxWxH) 4530 x 1695 x 1325 mm
GTS-T Type M Sedan Exterior dimensions (LxWxH) 4580 x 1695 x 1340 mm
So it's actually about 50mm longer, and 15mm taller... So I was right, it is more than 40mm, but not a lot more...
Thanks guys. i found in carsales.com.au tat 2 door is more expensive than 4 door. i also did some research than ceffy is heaviear than r32 4 door is tat true ? Also is ceffy parts find easier than r32 ? wat is the feel like both car ? i mean to compare them. i sat the cefiro seats b4. they r svcks. i hope r32 doest do tat though.
I also have few Question. If i use RB25 tubo into RB20 after fited do i need 2 change any thing else ? Like ECU, fuel pump,etc ?
Thanks guys on the opinion. i appriciated.
Cheers
Mick
Edited by Halo a
does it mean better 4 drifting
FKN A BROTHER,
Ive had both S13 Silvia, and ive got a R32 4 door now, and the difference in steering resopnse and over all feel of whats going on at the tyres is FAR FAR greater in the 32, *S13 and ceffy share the same suspension set up in the front*
Im in love with my 4 door, cant wait to dump it on my new suspension!!!!! as the feel will be erectifying......
As one bloke on here has in his sig, 4 DOORS 4 LYFE............
My 3c
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
    • I'm late to the party. Been busy with a newborn... Keeping me up at all hours of the night.  I'll look into purchasing ID 1750's then! Thanks everyone for the concrete evidence.
