Day Out With Kutsie, Take 2 (updated With Pics)
WogsRus
 Share
sounds like a plan, what time suit you best, i'm good after 7 or so.
If anyone is interested, you are more then welcome to join me an GMB at Joes garage in Market place, that is if GMB agrees.
7-7:30ish is fine with me old boy :yes:
Many hands make lite work and that means more people to shout me drinks and less trips to the bar :D
good to see mate, thats pretty impresive for a stock turbo :sorcerer:
yeah thats a good effort,
when i had my 33 pulled 213 rwkw on the stock turbo at 12psi.. that was the maximum though. although it was very well tuned by Colgrave Automotive...
was happy with it.
Beef
Edited by Beef
 Share
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
