Day Out With Kutsie, Take 2 (updated With Pics)
Sounds like your having fun with 200rwkw just wait till you get a nice big turbo and feel a real big kick in the ass as it comes on boost.
You could donate your rear tyres to me and i will take you for a blast with 400rwkw :happy:
Hell yeah GMB i'll come down and have us some brewskies. No probs.
Well it looks like you have twisted my rubber arm for a drink or 3 :mellow:
Who knows maybe Georgie wont want to come :)
sounds like a plan, what time suit you best, i'm good after 7 or so.
If anyone is interested, you are more then welcome to join me an GMB at Joes garage in Market place, that is if GMB agrees.
7-7:30ish is fine with me old boy :yes:
Many hands make lite work and that means more people to shout me drinks and less trips to the bar :D
good to see mate, thats pretty impresive for a stock turbo :sorcerer:
yeah thats a good effort,
when i had my 33 pulled 213 rwkw on the stock turbo at 12psi.. that was the maximum though. although it was very well tuned by Colgrave Automotive...
was happy with it.
Beef
Edited by Beef
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
