Hi guys,
I have already sold the Z33... and these pole position seats are actually off the car for sale....
THey will come with Recaro special side adaptors, geniune Recaro rails for Z33 (if you don't want that, it is fine too with a different price), Recaro driver side lumper support. I will also throw in a pair of Nismo airbag sensor plugs for the Z33, so you will not have the airbag warning light and the rest of the airbags in the car will still work properly!
The side adaptors that I am using are specially made by Recaro Australia (not shown in the photos), it looks a lot better and neater than those in the photos... I have those ones in the photos sitting around too, but the seating position is way too high for all of us.... so Recaro Australia specially made those side adaptors for me (of course with extra money) and the seating position is at the stock position now.
Pole position seats are slightly wider than those normal SP-G seats... Porsche GT3/2 seats are actually made based on the pole position SP-G seats, just with a different upper design...
These seats can be engineered and approved for the road use... I have done that with proof/receipt from Burwood Vicroad... so there is no problem with other States I believe!
Each seat is about 11KG (including rails and adaptors)...
Here are some photos of those seats....
Brand New Price: $AU 5,000.00
Asking for $AU 3,200.00 for a pair...o.n.o. (with Z33 rails)
Asking for $AU 2,800.00 for a pair... o.n.o. (without Z33 rails, but still comes with side adaptors)
cheers,
richie
Edited by nismo350z
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
