Hi guys,
I have already sold the Z33... and these pole position seats are actually off the car for sale....
THey will come with Recaro special side adaptors, geniune Recaro rails for Z33 (if you don't want that, it is fine too with a different price), Recaro driver side lumper support. I will also throw in a pair of Nismo airbag sensor plugs for the Z33, so you will not have the airbag warning light and the rest of the airbags in the car will still work properly!
The side adaptors that I am using are specially made by Recaro Australia (not shown in the photos), it looks a lot better and neater than those in the photos... I have those ones in the photos sitting around too, but the seating position is way too high for all of us.... so Recaro Australia specially made those side adaptors for me (of course with extra money) and the seating position is at the stock position now.
Pole position seats are slightly wider than those normal SP-G seats... Porsche GT3/2 seats are actually made based on the pole position SP-G seats, just with a different upper design...
These seats can be engineered and approved for the road use... I have done that with proof/receipt from Burwood Vicroad... so there is no problem with other States I believe!
Each seat is about 11KG (including rails and adaptors)...
Here are some photos of those seats....
Brand New Price: $AU 5,000.00
Asking for $AU 3,200.00 for a pair...o.n.o. (with Z33 rails)
Asking for $AU 2,800.00 for a pair... o.n.o. (without Z33 rails, but still comes with side adaptors)
cheers,
richie
Edited by nismo350z
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
