R33 Bodykits
Adz2332
 Share
I love it. That's the first time I've seen it on a normal (i.e - not the orange Msports R33) car and it looks awesome. You've just sold me on the kit :)
that bonnet is very hot! what is it?
yer it is hey, i saw one on a 33 down in Port Adelaide very hot.. but yer dunno wot its called hoping somwone can shed some light on it for me to...
the monkey warehouse m-sports kit rear bar looks sweet as, dunno about the skirts and front bar tho..
What is the difference between monkey warehouse msports kit and just the msports kit? Is it a copy or is that where the genuine kit comes from?
well there you go i never new that monkeyware house m-sports kit was a copy and yeh it definalty looks better when its not on an orage car covered in stikers. how come no one likes the front bar i like it cos its different from every other bar arround that ive seen i havnt see one other car on these forums in the photography section with this kit. maby no on elikes it lol o well i do oh and to (sauce) who said i just convinced them to buy this kit i got it threw www.dmdtheimage.com anf it was $1100 with front indicators.
Edited by munro'sgts-t
They call it the E series bonnet, i got myn from autobarn up south for 1400 but it was the new silver colour and the first in adel. Silver looks ugly but it was to get painted so dident bother me, if you wana cut the middel man out ring jet speed in Qld as they deal with that type.
i just looked at the piks of both the m-sprts kit and the Final Konnexion kit and the rear bar and the skirts look identical and the front bar is similar just without the indicator holes basicly. it leads me to belive tha tmaby the m-sports kit is a copy of the Final Konnexion kit.
Im trying to find some BN skirts and rear bar, Trust front bar and the bonnet in the pic. to suit a r33 of course
i know this might be a long shot cause its in england but a fella called martin can make up a carbon fibre reinforced front bumper for the R33! it looks like a standard GTR but with a few minor differences, you can email him [email protected]! its the best quality i've ever seen, and thats saying something cause FRP doesn't last long on the irish roads we have to suffer on on a daily basis!! i'l try and post a pic but if i cant, martin can foreward some on to you!
Carbon Fibre front bars get ridiculously expensive and with little benefit. Most of the time you want a flexible front bar not a rigid one, as this flex will absorb any force and hopefully not split or crack the bar. We are going to be releasing our own version of the GTR/Trust style front bar.
Here are a few sneak preview pics:
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
