  • Replies 42
  • 4 weeks later...
So since this thread is dead...can we take it in a slightly different direction. Copy, complete and paste the following info into your post :ninja:
Cam Brand -
Specs - (I:Duration/lift , E:Duration/lift)
Turbo -
ECU -
Before, Power - @ psi
After, Power - @ psi
Dyno sheet
It seems so far a few ppl seem to have tried Poncams and HKS Step 1. I shoudl have some results up in a few weeks.
Cam Brand - Tomei Poncams
Specs - (I:256/8.5 , E:256/8.5)
Turbo - gt2876r .64 housing
ECU - haltech e11v2
Before, Power - ? @ psi - didnt get a power reading before doing all the work to the engine
After, Power - [email protected] psi
Dyno sheet - dont have a scanner
quincy777- mate ill tell you this. i have had an RB20DET in my GTRST b4 and the mods i had was:
Custom Zorst Manifold
GT3040R with .63 housing
Sard 550cc
EMS stinger
bosch 910 fuel pump
forrged pistons (Arias)
Custom FMIC
Now, i was running 1.5 bar of boost and she made 230rwkw. I ordered Tomei 256 with 9.5 lift cams that was for an RB25DET engine and my mechanic fitted them. then car was tuned at 1.2 bar boost and made a 261rwkw.
The point is that i invested $1500 that was NOT a waste.
Cheers
Babak
230rwkw on 1.5bar wtf that sounds like a fair average figure for that setup...
ECU - haltech e11v2
Who tuned the car? Have they any experience with cars with the same setup as you less the cams?
I have searched high and low and im not able to find a single definitive example where a setup had been run for a period of time, then had cams thrown at it and tuned by the same guy on the same dyno and actually made more power.
LOL...it doesnt appear as though such an example exists :)
If you were after an rb25 example i meet all those criteria. 30rwkw gain with no other changes.
it was tuned by richard at allstar performance systems here in qld, your best bet would be to email dan from elite racing at [email protected] and ask him about his personal rb20, i know he did see results from changing to poncams.
I have Cams in my RB20, with GT3040, 25psi, boost came on hard and all the way to 8.7k, made close to 290rwkw untill it received some forged piston melting conditions. lol.
a better tune and more fuel with new engine should see it hit over 300rwkw.
i know this is all about cams but im not for giving out my specs, but yes they sure make it alot better. more power and response and yes the cam gears were adjusted.
Edited by boostn32
have some faith troy.....my car is in the shed with its cams out, ready for the new ones (256/8.5)....just waitin on the water pump, belts, tensioners
should be fairly soonish
LOL...fair enough. But there is enough 'trust me..wink, wink" stuff going on. Im looking for hard tangible results :)
Can you at least post a dyno sheet?
Look forward to seeing your results as your turbo is a bit smaller then what im running.
Honestly. Based on my experiences with my setup...i agree. Its all in the tune and being willing to run the 18psi with a decent turbo.
What are std Rb20 cams and std RB26 cams. Sure the lift is a little different but the durations isnt overly different. So perhaps the std Rb20 cams are decent enough. I know my power whilst trailing off up top didnt exactly fall over
so true, if anything the rev limit needed to be raised
would obviously differ between setups, but goes to show its possible
anyway, graphs have been pissing me off as of late, going to WSID on the 25th.
Edited by silver gts-t
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
