Hi guys,
We have just received a delivery of our brand new Stainless split dump/front pipes for Nissan RB20DET & RB25DET equipped vehicles..
The JJR Stainless Split Dump/Front Pipe is a super high flow combination front/dump pipe featuring innovative product design along with guaranteed performance and fit quality at a truely unbeatable price.
Just Jap Racing is pleased to offer SAU forum members discounted pricing on this great new product.
PRODUCT INFORMATION:
- Manufactured from high grade Stainless Steel pipe
- Stainless Flanges used at both ends (8mm Turbine outlet flange - 6mm Cat flange)
- 2.3mm wall thickness - 3 inch main pipe diameter
- Specially designed moon shaped wastegate divider
- Uninterupted exhaust gas flow through seperate of turbine exhaust and wastegate gases
- Factory 02 sensor screws straight in
- Guaranteed performance
- Guaranteed fitment
- Impeccable weld quality
- 12 month warranty
AVAILABLE TO SUIT THE FOLLOWING VEHICLES:
- Nissan Skyline R32 GTS-T (RB20DET)
- Nissan Skyline R33 GTS-T (RB25DET)
- Nissan Cefiro A31 (RB20DET)
GUARANTEED QUALITY FIT & PERFORMANCE - UNBEATABLE PRICE!
We have close to 100 of these beautiful stainless dump/front pipes in stock, ready for immediate pickup & dispatch, so unlike other deals floating around the net, there is:
1. No deposit required
2. No minimum order
3. No waiting
4. Easy online payment options
5. No surprises
Deal with an established and trusted company! - Not a backyard trader
SAU FORUM MEMBER PRICE - $269.00 + DELIVERY
OPTIONAL X-FORCE 3 INCH HIGH FLOW CAT's AVAILABLE FOR $160.00 DELIVERED
HOW CAN YOU PLACE YOUR ORDER?
The answer is simple!
Purchase online now via our massive new website at http://www.justjap.com for fast Australia-wide delivery.
With Australia's biggest range of High Performance Japanese Parts all under one roof, and all available online, purchasing your tuning parts online couldn't be easier!
Please contact our sales team if you have any questions, or reply here
  • Replies 65
Ooo, nice. Do you have this available in a screamer spec also?
Hi Jordan, we have individual screamer dump pipes on their way, but no screamer dump/front pipe combos at this stage.
Cheers,
Steve >_<
All Pm's replied to :)
Keep the orders coming guys - We have 100 of these in stock and they are selling fast.
Questions? Please dont hesitate to ask.
Cheers,
Steve
Hi mate,
Are you going to have a Catback exhaust kit available anytime soon for the r33/34 like you for the s13/14?
We certainly are >_<
R32 and R33 stainless turbo back systems will be available within the next month.
Regards,
Steve
What's the internal diameter of the dump pipe?
Hi Brett, im in Japan currently but if you give Darron a ring on (02) 9545 0532 he will be only too happy to measure one up and confirm the exact inner diameter for you.
If you have any further questions please dont hesitate to ask.
Cheers,
Steve
Hey mate,
Will these split pipes be suitable for a highflowed turbo? as in the moon shaped divider will not be in the wrong position to direct flow?
Cheers.
Hey mate,
Cheers.
If you are talking about a high flowed factory turbo that can still use the factory dump then you shouldnt have a problem.
Other upgrade turbos like the HKS GT range could require that the divider be removed.
Regards,
Steve
Hi,
im very interested in one for a R34 GTT (in stainless). are these available? if not when will they be and does the $249 price still apply to these?
Hi mate, thanks for your enquiry.
We are working on them for ER34 and other models at the moment and we hope to have them available soon however I dont have a definate ETA just at the moment.
The forum pricing of $249 will still be available when the ER34 versions come into stock :)
Cheers,
Steve
The forum pricing of $249 will still be available when the ER34 versions come into stock :kiss:
Cheers,
Steve
thanks for the reply. can you please update this thread as soon as they are available so i can get one of you guys as i am very interested.
Cheers... :)
  • 4 weeks later...
Thanks for all the orders guys :blink:
We have a number of these JJR Stainless Split Dump/Front Pipes in stock however they are selling very fast.
Get in quick!
Cheers,
Steve
    • Gas MIG for learning, I was able to weld up some nice 1.6mm tubs so you can do thin stuff easily enough. Then moved on to thick caliper adaptor brackets with the same machine, all good.  Arc/Stick is great for dirty garden work etc, but Gas MIG for starting on car stuff.  Jump on the NCR FB page and search ATP Tubs or GKTech caliper adaptors for pics/info. I'm no pro but it wasn't hard to learn. Be willing to grind and go again though if it's cold etc.
    • That's not a bushing!
    • Oh and I got myself a grandpa spec dash mat.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
