Rb26 Rods And Pistons. Also Tomei 1.5mm Oil Restrictor
Would it be stupid to twin charge a skyline? Would that be possible/practical to do on an rb engine?You totally couldn't have that many cars running on Ethanol. You'd be employing two full time mechanics just to keep going through the vehicles, flushing old fuel out, and possibly changing anything the ethanol has eaten between the months it would be between drives.
A fine grit media blast would make short work of it after you tape up everything I grabbed a cheapo Ozito one from bunnings for about $30 that I used to clean up some old brake calipers and some brackets Messy, but fast Wear PPE though, stuff dusts up and is really bad for your lungs and eyes
It's not true. RBs only have one gearbox bolt pattern. I mean, I was surprised that there was a different clutch bolt count on the weak NAs, but that's on the flywheel, which is not part of the engine.
They just said 40 grit lol I wasn't going to try and get them to do it, needs more care then they would give it.
Hi I wrote to the xtreme clutch and they wrote me this: Thanks for contacting us. I already spoke with engineering team and was told that RB25DET with a non-turbo fs5w71c gearbox would not work. It would not hold the horsepower and does not bolt to that engine without some sort of adapter plate or modified bellhousing. I know about the power(it will hold stock power) But i rly dont know about not bolting to the engine without some adaptor?? Is this true? I thought it should mate up without any problems...
