Not needed parts due to RB26/30 race engine build for the 25t.
Large items pickup South Morang Melbourne. Postage/courier at buyers cost for smaller items. All offers considered. Pickup before 28 Feb 06 or they will be relocated to Brisbane.
RB26 parts.
R34 stock turbos, $800 as paid for when I bought them for my RB25DETT project, I drove them 3km.
Polished plenum with throttle bodies, $350
Injector rail x 2, $80 each
Injectors x 6, $300 Sold.
440cc Toyota (I suspect) injectors x 6, fit RB20, 25NEO, 26 but different plugs needed, $250
Con Rods, $300 come with ARIAS RB25det forged pistons that are scored and 1mm oversize (87mm) so may suit resize to 86.5 or 86mm with new rings.
RB25DET parts
Complete head with cam covers, no plug cover, pitting in quench zones on 1,2,3 from whatever scored the bores but nothing a surface won't eliminate $400 Sold
Injectors and rail, $150. I can have these highflowed to over 700cc for about $75 each if desired for stock look.
Intake including throttle, runners, gasket plate, $100 Sold
Stock exhaust manifold, $100
Stock rods linished and polished, $150
RB26 manifolds cut and welded to suit RB25DET head, $150Sold
Stock oil cooler/filter mount with hoses, $30
Bottom end, no pistons or rods or harmonic balancer or oil pump, includes stock sump, oil pickup, rear main housing, water pump, crank and cradle, oil squirters, cam belt drive, dipstick, O ringed, crank straightened and grub screwed and oil ports chamfered. Has been scored so will need oversize to 87.5mm $500
RB30DE parts
Rods from SII RB30DE motor with stock pistons $50
Oil Pump, $50
There may be other parts left over after the build but I need most for the new project. I'll update as I find stuff to get rid of. Don't ask for pictures, we all know what this stuff looks like. I'm prepared to do a deal for bulk lots.
Contact Geoff
email preferred to PM (in sig), or call 0408124767
>_<
https://www.sau.com.au/forums/topic/155266-rb-252630-engine-parts-fs/
This is a standard side feed RB26 plenum with six throttles. It doesn't come with the section for the injectors that goes between the head and the throttles. It won't bolt up to any other RB head without an adaptor plate. One possible solution is to cut the runners and weld on a plate for the throttles to bolt up to, which is what I was going to do with it on an RB25.
Done.
Updated, forgot to mention the head is slightly pitted in the quench zones due to whatever went in and scored the bores. Photos attached.
kinda interested in the turbo's Geoff, I'll do a search for specs and see what if anything is needed to fit them to my r32 (pretty sure my car has aftermarket dumps)
if you have the details I need pm me when you get a chance, in the meantime I'll try and hunt up specs myself
cheers
Sorry I was off for a couple of days in Brisbane. Ran 2 cars up and tried to buy a house but no joy.
Anyway the head and RB25 intake are sold.
Tristan and Simon you are welcome to the turbos if you want them separate, but not sure why as they are too small for any single application like an SR20 or CA18. First to pay takes them.
Likewise Jesse. They are a straight boltup to any RB26 manifolds and dumps but they need the bolt on lines.
Scott, I'll grab pics in a moment and check to see if RB20/26/30 plugs fit. I'll be at the meeting Tuesday and the cruise so we can catch up then if you want.
Pics of the injector socket with a GTR/RB30 plug and also a GTR injector. The plugs don't fit mate but I bought the RB30 plugs from Bursons so they could help with something suitable.
The injectors have the following numbers: 8E25 and 23250-42018
post-6392-1171433326.jpg post-6392-1171433470.jpg post-6392-1171433705.jpg post-6392-1171433728.jpg post-6392-1171433756.jpg post-6392-1171433965.jpg
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
