Garage Cleanout: R32 / Rb20det / S13 / Ca18det / Sr20 / 300zx Parts
HEAPS of stuff for sale!
Most prices are negotiable. Make an offer by PM.
Cheers - Michael & Kaz
Location: Northern Suburbs Melbourne - Epping (or could pickup in city during business hours, with notice)
Payment: Cash on pickup, direct deposit, or Paypal.
Postage: Will post most items, or pickup can be arranged.
!!WTB!!
Willing to swap any items listed +/- cash for:
* Oil Temp Gauge 80mm (prefer full sweep but not necessary)
FOR SALE:
R32 RB20DET (silvertop):
* RB20 S2 Turbo - $sold
* RB20 Turbo Elbow - $40 ono
* RB20 DET AFM to Turbo rubber inlet piping/hose - $40
* Valley / Coil-Pack / Ornament Cover $50
* RB20 Standard Injectors x6 $50 SOLD PP
* RB20 Intercooler $30 SOLD PP
* Ignition Loom $50ono
* Stock Intercooler piping & elbows $offers SOLD PP
* RB20 Polished/chromed Cam Gear cover (from Series 1 so RB20 Embossed) - $100
* R32 Eyelids - Fibreglass. Stick on. Unpainted. Brand New. - $80
* R32 / S13 Standard Tension / Caster Rod. Bush starting to wear, but not split. See pic in S13 section below - $40 ono
* RB20 Alternator - $60ono
* RB20 BOV Relocation setup. Suit multiple applications with the same flange. Previously used on RB20 into S13 conversion - $80ono
* RB20 stock BOV and oil breather recirculation piping - $offer
* RB20 TPS - $60
R33 RB25DET:
* RB25 wastegate actuator. - $50
* R33 AFM -> Turbo Rubber Hose $50
* R33 Ignition Loom $50ono
RB26 Bits
*RB26 Fuel Rail - $100
S13 180SX SR20 & CA18 parts
* S13 BLITZ Coilover (rear) 3-step damper adjust. not height adjustable. One may be leaking? - $150 ono
* R32 / S13 Standard Tension / Caster Rod. Bush starting to wear, but not split. $40 ono
* CA18DET Cooler out to Throttle Body Piping/piece $40
* CA18DET AFM to turbo rubber hose $50
* CA18DE AFM to turbo rubber hose $40
* CA18DET Idler Pulley (Brand new) $140
* CA18DET Tensioner Bearing (Brand new) $90
* S13 OEM Centre Aircon Vents (brand new in box) $90
* S13 Aircon Vent Motor $offer
* S13 Centre Console
* CA18 Fuel (Injector) Rail $offer
* CA18DET Stock Cooler Piping $offer
* CA18DE & CA18DET & SR20DET airboxes - top halves only $offer
* CA & SR Resonator boxes $offer
* SR20 AFM $offer
* SR20DE Airbox complete with filter $60
300ZX
* 300ZX various intake piping (have a lot - ask if I have it >_< )
* 300ZX airbox $offer
* 300ZX BOV - $offer
Supra
* 2JZ Supra injectors & fuel rail - offer$
Soarer
* Soarer injectors & fuel rail - offer$
* Various Injectors & Rails (mostly Toyota celica/soarer/supra)
Still need to add some more items.
Everything else previously listed has been sold, thanks!
  • Replies 50
Posted Images
  • 3 months later...
Sent the AFM>turbo hose to Pete on Thurs, pretty sure that's the last one.
Have the same hose for an R33 and a CA18 and some of the piping that comes off it, incl the RB20 piping
Sold AFM>turbo hose for RB20
Sold 180sx taillight
Sold CA18DET timing belt
Cheers!
$40 plus post to tas for the stock RB20DET exhaust manifold? (will fit rb25det s1?)
cheers
  • 4 weeks later...
 Share
    • Oooohhh man did not bloody know that, that's amazing thanks heaps for sharing mate, bookmarked it!
    • In case you haven't come across it, there's also https://nissan.epc-data.com/ Go by VIN or drill down into your specific model and year and it'll have references for pretty much all the OEM parts. In very similar diagrams. Linked against amayama as well for ordering. Though they can be a bit slow and can be better to search around to get the parts locally.
    • Just in case anyone finds this in the future, here's a diagram sent to me by Nissan to identify these hoses. I ended up finding them through EFI Solutions though because Nissan reckons they need to order it from Japan, with a total cost of approx $110 inc. So it as cheaper with EFI anyway. https://www.efisolutions.com.au/blow-by-hose-rb25det-r33-wc34-c34-c35 https://www.efisolutions.com.au/blow-by-rocker-cover-hose-rb25-r33-wc34-c34-c35
    • This is an older post of mine but I just thought I should update it and explain what the problem was. Long story short the friction plates were below their service limit. New they are around 4mm, and service limit is (according to OSG) 3.5mm In addition the crank seal gasket wasn't sealing 100% anymore and that led to an oily clutch. Not sure what came first and why the clutch was worn after just 10,000km .. but all good now. OSG refresh kit via Nengun
    • My r34 GTT auto transmission is slowly letting go, slipping every now and again, tiptronic deciding to not keep it in 1st / 2nd when flooring it, taking longer to shift so I’m going going flush it and replace the filter and hope it lasts a bit longer.    I’ve got 10L of Penrite ATF FS at home and I’m going to use it for it unless ye completely recommend against it.  Penrite list it as compatible. i understand I should be using Castro Transzmax however it’s quite expensive and I already have 10L of the ATF fs. Has anyone here used atf fs for there got or heard of anyone? Or am I silly for even considering anything other then Castrol  Thanks for your advice
