as per title,
i'm after the Helvetic fonts... mainly just Helvetic Black, would like the whole lot but have you seen the price at linotype.com? :):(
would anyone be so kind as to either point me in the direction of place to 'obtain' this font family for free or to maybe leave a .zip file in my PM inbox :(
cheers,
daniel
https://www.sau.com.au/forums/topic/155285-helvetica-fonts/
