hey guys. sorry if this has already been posted.
looking at getting a R34 from Japan soon and found a nice r34 AWD. now im just wondering if you can pull the fuse to change it to RWD when i want to, like the R32's?
and also does the AWD model's have GTR running gear??
cheers Luke
https://www.sau.com.au/forums/topic/155309-r34-awd/
hey im wondering the same thing..
apparently u can do it, just pull the fuse out. and on the the dash wen u turn it on, the 4wd lite shouldnt show so that means ur running 2wd.
ive got a n/a r34 gt-four and yes they use GTR gearboxes. had mine converted to manual.
altho i dont want my car to b 2wd coz then ill b pressured into doin burnouts lol. tyres dont come cheap specially wen u have 265/35 19" wheels
https://www.sau.com.au/forums/topic/155309-r34-awd/#findComment-2888376
This is a fairly common question over in the Stagea section.
Stageas use the same AWD system as the R33 GTR.
The R32 was the only one where you could pull the fuse and thats all. In R33's/34's doing this will burn out your clutch packs.
I'm assuming the R34 AWD system is the same ATTESA (maybe with a few tweaks?).
You should be able to put it in RWD by removing the front tailshaft (the one from the gearbox transfer case to the front diff). Four bolts each end and apparently the transfer case is sealed so no need to cover that hole.
I'm pretty sure you need to remove the fuse as well.
I've never done it myself but I've had it done in order to use a 2WD dyno and it works fine. :D
So basically DONT just pull the fuse - you'll destroy your ATTESA AWD system.
Personally I'd prefer to leave it in AWD. On stageas some people have noticed about a 1 second difference between 1/4 mile times with AWD vs RWD on the same car (AWD being faster, no traction loss, better weight/torque distribution). AWD is also safer in the wet.
So if you're not doing burnouts/doughnuts then just leave it in AWD :yes:
https://www.sau.com.au/forums/topic/155309-r34-awd/#findComment-2898300
the 33/34 GT-R transfer case clutchpacks run some amount of preload (which is part of the reason why 33s and 34s oversteer less than 32s, as well as having ATTESA that updates more often), and which is why you usually have to disconnect the front drive-shaft to run 'em on a chassis dyno. But lots of drag 33s and 4s in Japan seem to have RWD switches, so it must be possible to modify the system, maybe just not cheaply.
https://www.sau.com.au/forums/topic/155309-r34-awd/#findComment-2901748
  • 2 months later...
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
