Okay, here's me all excited and bum up installing my intercooler that came today. Now I have a problem though ... I have come to the stage of fitting the top pipe and the destructions say to "Trim the fan blades down !" but when I look at it and size it up, it's more like " Hack the fan blades to death ! "
So, the question is, cutting the blades down until the top pipe fits in nicely, will this raise my engine temp at all ? Seems to me there will not be much left of the fan if I do. Should I remove the fan and wack in some thermos instead ? :laugh:
i had to do thesame on my R33. What i did was to get a texter, and mark up the top of the fan to cut off. I did this by holding the texter fixed, and then rotating the blade. I did this at the top and then the from the side inside the engine bay. This gives you two lines and if you join them, you get a triangular shape, about 3*5cm. I then pulled the fan off, 4 bolts, and used a grinder with a very fibe cutting blade, and trimmed the blades. Cleaned them out with some sand paper, and hay presto. The fan is still very balanced, a little noisier, as the curved tipps stop cavitation.
Hope that helps
Hey ive had mine installed now for a few weeks, and i had to remove the neo cover, and trim the blades slightly,
i havent noticed any differnce what so ever in performance or engine temp.
LOL just use the process of natural evolution... install the FMIC, close the bonnet and pray for the best. After 1000kms your fan will have either exploded or formed into a perfect shape for your FMIC Pipe :D
Nah, just mark it out with a pen and take bits off with a dremel... remember this though, take off LITTLE bits at a time... you would rather waste time doing little bits than to waste the fan / performance by taking of big bits.
My 2 c
PS: I am not liable for any damages caused with process #1
Sweet thanks bud :D
EDIT: What did you do for a water bottle ?
it's not performance nor engine temp you'd be worried about bryn, it would be not trimming them evenly.. centrifigal forces on an unbalanced fan can get pretty carried away if you don't do it properly :S i managed to keep my piping out of the way with a bit of playing around, ended up throwing a zippy tie or two around where the L shaped pipe bolts to the drivers side of the head as my dodgy piping didn't come with the mount welded on, and accidently snapped it playing around in the engine bay with the engine running one night and the fan blades trimmed themselves perfectly on the sharp edge of the pipe clamp >_< good times, good times.. definently remove the neo cover though
EDIT: About the water bottle - he doesn't have one anymore :)
Edited by aphid
R34GTTs will require you to either modify the stock washer bottle (which is a royal headf**k) or go and get an aftermarket replacement from Supercheap or similar.
We get a $30 generic one which fits next to the battery making it look rather OEM actually. I must say, the capacity of this is like 1L so don't expect the same amount of "squirt" as the stock item >_<
it's not performance nor engine temp you'd be worried about bryn, it would be not trimming them evenly.. centrifigal forces on an unbalanced fan can get pretty carried away if you don't do it properly :S i managed to keep my piping out of the way with a bit of playing around, ended up throwing a zippy tie or two around where the L shaped pipe bolts to the drivers side of the head as my dodgy piping didn't come with the mount welded on, and accidently snapped it playing around in the engine bay with the engine running one night and the fan blades trimmed themselves perfectly on the sharp edge of the pipe clamp :) good times, good times.. definently remove the neo cover though
EDIT: About the water bottle - he doesn't have one anymore :w00t:
Washer bottle will be installed on the other side... where stock cooler once was, once im bothered enough to take bumoer off again
hehehe self trimming fan :cheers:
so what u end up doin..?
the trim job or.. let her do her thing..?
u found no performance gain in having a FMIC? my GTir Saw a noticable gain.. some what 20kw ontop when she boosted to 16psi and advanced timing... but she used to have an old shitty top mount interwarmer with oil in it. :)
yay for rally cars.. mini GTR :)
Thanks guys I have finished it today, she's up and running. Didn't have to trim as mush as a thought. Neighbour thought I was a bit mad when i started the engine and held a sanding block to the edge of the fan :) this was after the beers kicked in. Looks KO to me .
hmm. on 12psi on the GTiR u get a nice boost in power. noticably quicker. on 12 it allowed me 2 pull 2 carlengths infront of my mates GTS25t running 14psi.. haha. and the 16 saw me over the horizon. so i guess the TMIC setup was just too wasted. maybe u dnt get power increase with the fmic. but cooler charged air should always give more power..
I have been out and about driving and noticed the difference, nothing astronomical but a definate difference.
At the same time paranoid about a hose/pipe blowing off, so I put my whole garage in the boot just incase :woot:
I will be going a new radiator and thermo fan next week getting rid of the MixMaster.
http://www.youtube.com/watch?v=da00B05c8yU
Nothing yet bud , thinking of welding up an aluminium one. :) A Big sucker too, something that I can brew beer in. :woot: and link it to water spray for the FMIC aswell . Alot in the works for the grey matter.
Well if u do make something like that :) pm me as i will pay you for one the same :)
Looks good
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
