BP is the only refinery in WA anyway, so technically it'll still be BP.
Usually other Brands put there own magic additives in the blend...
but otherwise it'll mean 98 will be easier to get in those situations where you would normally have to hunt for a BP... i think everyone here has had that experience at least once.
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2888871
ok... who here every time they fill up on bp ultimate put a bottle of octane booster in as well? ive heard that the fuel in japan is 101 octane and that with our fuel we should put in a bottle of octane booster aswell
that would probably make your fuel 98.1 octane and give your plugs a beautiful orange colour
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2890148
Dan, there actually some good octane boosters out there. Besides orange is pretty.
Can anyone CONFIRM where Peak get their 98 octane from. Is it in fact BP or is it from Singapore?
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2890485
Well this is great news. The only reason I went to BP was because they were the only ones who had it, now that peak and caltex do i'll be able to shop around. Sure i'll probably only save a few cents each time I fill up, but it's more about the principal :laugh: (and the fact that I hate BP because they are always more expensive and bump up their prices randomly with no valid justification for doing so except to rip people off)
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2890902
Well they all change their prices randomly. BP is no different.
Anyway why do you hate them so much. Just think where we would all be if BP didn't sell 98 Octane?
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2890932
Just been on the phone to Peak. They often source their finsihed product from Singapore, but the chemist said their 98 is sourced from a Mobil refinery and is the same spec as the Utimate. I assume Caltex is sourced from one of their east coast refineries but I have not been able to confirm this.
Forgein ayyy! Good info skylion.
Should be cheaper but wont be as they colude to keep prices artificially high. Depending on what, if anything, is used to boost the octane rating, toluene (methylbenzene or phenylmethane) or ethanol it is reasonable to expect your tune up to change. I would be very careful with trying different fuel, check your AFR's and be prepared to make the changes. Hp gains have been made by Skyliners on the East Coast using Ethanol boosted fuels. Caveat emptor
Nicking fuel from the airport LOL mmmmm JetA1
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2891618
imagine running jet avo fuel and having a bee*r limiter!!! = massive flames
pop, pop, pop, KERBANG, wooooooooooooooooooooosh!!!!!!!!!!!!
wouldn't adding ethanol and/or toulene be a good thing for your car as it burns better and cleaner?
if it is i can see how ur tune would change anyway
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2891921
keep it on topic please. there have been plenty if toulene threads before which has covered all of this.
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2892058
    • Oh right, I didn't realise it was your car. Please do! Makes me feel better about mine. I also have a big scrape on the front left bumper where someone presumably used the wall to guide the car into a parking spot  But somehow all the funds go towards mechanical things and the cosmetics stay forever unfinished... Interesting, I don't think I have seen it before. But after seeing @PranK's rusty roofline on the BMW I'd probably leave it alone. Wouldn't want water to get in there.
    • Thanks mate, thought you might know the answer.
    • Infiniti US are teasing a manual Q50 as a way to refresh a (very old) model. https://torquecafe.com/manual-performance-sedans-arent-dead-yet/ Can't be too technically difficult given the Z has the same motor with a manual gearbox......here's hoping there is a JDM version we can import here, that would save me a world of headaches
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
