hey, i was canaried a few days ago for a few things, such as ride height, unroadworthy tyres, parker bulbs blown, pod filter and loose front bar. now im not bitching in any shape, way or form because i knew i had this coming. all i wanted to know was that the officer said something about EPA. does this mean that i will be sent to EPA to check if my defects have really been cleared (due to dodgy rwc's) or that they will do a FULL inspection of the car in general? such as ALL modifications on the car.
any feed back would be awesome, especially those who have been in the same position.
cheers, Miguel
https://www.sau.com.au/forums/topic/155325-question-on-epa/
EPA aren't there for defects or dodgey rwc etc etc.
They are there to check your noise level output and your exhaust gas emissions.
If you have a cat and all the pollution gear intact, no aftermarket ecu/turbo, no boost controller and only 1 intake mod, you should pass the emissions test.
If you exhuast is under 90dB, you'll pass the noise test
https://www.sau.com.au/forums/topic/155325-question-on-epa/#findComment-2888643
awesome awesome! as i have a dr. drift remap, hiflow and a spare stock muffler (read 84dB), i should be able to pass if i take out my bleed valve and pod. would they check injector flow? as i have nismo 555cc and dont have the stock ones anymore :D
https://www.sau.com.au/forums/topic/155325-question-on-epa/#findComment-2888660
Depends on what type of EPA he gets
Macleod, or just an exhaust test.
Macleod wont pass ECU mods, injectors, turbos anything.
You might be lucky and get passed, you might be unlucky and be pinned for each modification
Its your own gamble if your off to Macleod
https://www.sau.com.au/forums/topic/155325-question-on-epa/#findComment-2888855
if i am off to macleod, id be prepared to change everything over back to stock, wouldnt be that much of a bitch would it? would my car still be drivable if i swapped my 555cc injectors with the stocker? tune is under 200rwkw so stock injectors are still capable. just need to know if itll work.
https://www.sau.com.au/forums/topic/155325-question-on-epa/#findComment-2888867
Its highly likely they will also check the ECU
So you'd need to return it back to the factory item (un-chipped)
They opened my ECU cover up 18months ago, so the EPA are well aware of the fact you can "chip" stock ECU's
cheers
https://www.sau.com.au/forums/topic/155325-question-on-epa/#findComment-2888883
Yeah, sometimes they are... sometimes they are not.
I had a rough exam, where others have passed with as many things as i was failed for.
As with everything related to law application... its sometimes accurate and sometimes just amazing the things that are not even looked at
https://www.sau.com.au/forums/topic/155325-question-on-epa/#findComment-2888906
When i was sent to mcleod, i was in my old car: Onevia RB20DET, hks2540R, 440cc injectors, full exhaust, dr drift remap etc...
I passed, they checked for BOV, Boost Controller, they did check for aftermarket ecu but they only pulled the plastic cover of they did not pull the computer to bits to check for chip etc...
They did check for aftermarket turbo, but as mine was still lowmounted and had all stock heatsheild on it they passed me...
And they also check for engineers cert if you have engine swap etc...
https://www.sau.com.au/forums/topic/155325-question-on-epa/#findComment-2888928
Guys,
I just got done by police for an EPA noise test. The officer pulled me over, went thru the usual licence check, breath test etc, then said for me to be on my way and he will send me an EPA notice. Whould I have got something off him at the time? Or does it just come in the mail?
Also, from a search on here I have found its measured at 60% of your redline, and that the limit is 90Db. (I have a 1990 R32 GTR). I have a 3inch full turbo back exhaust. No other mods other than like pod filters etc etc. What distance is the 90Db measured at?
Will a swap to a stock exhaust solve my problem?
Cheers for help guys!
Anyone with a stock 32 GTR exhaust, let me know! I need to borrow!! :mellow:
Dan :)
https://www.sau.com.au/forums/topic/155325-question-on-epa/#findComment-2897968
Ok... as for him sending you something.
Its just as he said, it will be sent. Being it wasnt gien to you on the spot, that really only leaves mail as an option, so yes... as the officer said. I will be posted.
RB26 RPM test is 5200RPM.
If you have aftermarket front pipes, a stock GTR doesnt even pass. SO you will need to chat to an exhaust place about "measures" to lower it.
https://www.sau.com.au/forums/topic/155325-question-on-epa/#findComment-2898059
iv got aftermarket front pipes,no cat and 3.5" exhaust, and had to do a noise test,
the exhaust place i took it to said theres no point in testing cause it was a lot lounder then 90db,
so they just cut of my rear muffler and welder flanges on to it a fittied a 2" muffler and i think that got 86db.
https://www.sau.com.au/forums/topic/155325-question-on-epa/#findComment-2898353
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
