I know what the Faq says
but my friend says that according a few companies thge GTR suspension all around is what is called for with teh stagea??
it contradicts everything ive read here
gtr fronts fit stageas yes, gtr rears dont fit unless its a series 2 manual from the factory. gts-t rears fit but they are not designed for a wagon and wouldnt be very suitable.
so what coilover setup would be suitable?
the whole shock spring setup most of you run will not be quite enough for my application.
IS there a certain reason why GTST rears arent suitable?
oh and i dont think that spring shock combo will go quite as low as i need to be. I had to modify my coilover lower brackets to go as low as i needed.
Hopefully to have the stagea on stock body about 3-4 inches fromt eh ground.
yes lowering is an issue, ive got mine with about 100mm of clearance from chassis to the ground and exhuast is about 60mm from the floor, i can go lower at the rear but not the front as the strut bottoms hit the control arms :D i have circlip grooves down to 300mm from wheel centre to gaurd but with the lowering issue i can only goto around 315mm.
sydneykid will know the spring rates etc for the setup he sells.
Edited by CruiseLiner
which is why i wanted to go with coilovers
i know how to make big wheels fit small spaces
plans are to put 18s, slam it and drift it, like i did with my 180.
Ponly problem is flaring the rear fenders to fit the single digit or negative offsets i want to.
But unless i have a manual stagea from the factory (wihch obviously i dont)
I need GTR front GTST rear.
rodge
I have a set of Gab wagon coilovers which is so low at the moment that I scrape on a speck of dust on the road, they are also hard/soft adjustable as well as height.
Couldnt tell you what model, unless you know where to find it on the coilovers themselfs?
Since you are Japan you have a heaps of options
There are heaps on Yahoo auctions suitable for the Stagea and drift
Tein make several different sets
I have Tein Wagon's which have 4kg Front and Rear, but they also have Tein HR which are approx 10/8kg F/R
ive already got a company lined up, i was just getting contradictory information
My suspension sponsor from my 180 is hooking me up with cost on another set
i was just making sure on what models to get with the front nad rear
  • 4 weeks later...
tanaka wont do it scotty
but a guy back home is a distributor for the same shit that was on my 180
and he can get 20mm shorter front shocks and custom springrates with the shocks valved to match. for an ass kickcing price
what do you mean he wont do it... i just went over there the other day, and it actually came up. well he is kinda choosey like that... oh well... good luck with that...
but it can be done... why not just buy a set of S14 CO's, R33 Uppers and go at it... oh well...
why dont you go up there with me, they didnt quite understand what i was trying to do.....maybe you can help me out?
i need something that is shorter than this
from bottom of tophat to bottom of the shock (out of lower bracket) is 33 cm
with the lower bracket it is 36 cm
i need like a 30-32 cm shock possibly shorter
Edited by yokotas13
  • 5 months later...
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
