heres the for sale ad of some rims im after....
"To suit R33GTST and R34 GTT, and possibly R32 GTST(will also fit S14 or S15 Silvia)
Details and image below:
2 x 18x8" with 235/40/18 Nankang's (front) 5x114.3 stud pattern
2 x 18x9" with 265/35/18 Nankang's (rear) 5x114.3 stud pattern
* has minor gutter rash on outer lips which can be machined/polished
Not sure of the exact offset but the entire set were a specific fitment for R33 GTST. I've been told they will also fit the above mentioned cars too."
will these be the correct offset for a stagea if they fit a 33 gts-t???? will they stick in or out the gaurds and by how much?
any info appreciated
Brad
Edited by CruiseLiner
https://www.sau.com.au/forums/topic/155349-will-these-rims-fit-a-stagea/
Brad
do me a favor
find out the offsets of hte wheels and i can tell ya!
offsets are my specialty lol
yeah
the problem is, what people say fits are a few different things
some people say this fits
(kinda does but not perfect)
i say this fits
but then some think this fits
i personally on a stagea would be going after the last fitment
mainly becuase to roll the fenders ont eh rear will make an UGLY little dimple where the door frame area is.
those wheels in the last pic on a S13 with no spacers was a 16x8 +10 offset.
most people say that +30 "fits"
Edited by yokotas13
Brad, My old rims were 18 by 9 on the rear and 18 by 8 on the front the offset was +40 and they fitted, Mind you on the rear the tyres were stretched on so the tyre wall was on an angle, but im not sure if this was because the tyre would have hit the inner gaurd.
anyone know if staggered wheels are a bad idea with the attessa or are they ok if they are within a certain percentage of each other (profile wise im talking)???? i read within 5% of eath other is fine?
Not a good idea apparently Brad, even worn tyres on the rear (same rim sizes) has been know to effect the system in the past as far as I have read on this forum, search and you may find...
You might get away with it but I wouldn't risk it personally.
Cheers
Luke
Ok so I did the searchy thing...
The ATTESSA handles different tyre diameters due to wear ie; you can have barely legal tyres on one end and brand new tyres on the other end. That's a 6 mm difference in radius, 12 mm in diameter and 37 mm in circumference. That's covers most width profile differences easily.
Real world, my Stagea doesn't like 225/50/16's on one end and 245/40/17's on the other end. After less than 1/2k driving in a straight line, the ATTESSA started to shudder. I had to turn the steering wheel (for imaginary corners) to stop the shudder. I must have looked like a lunatic, warming the tyres up driving down the freeway.
:) cheers :)
So if it is an extreme difference it might be an issue, or if it is minimal it may never be a problem.
(Simon, when did you have different wheels? I thought the current wheels were on the Stagea when Chris imported it?)
Cheers
Luke
thanks guys, yes mine has gtr tf case now and the gtr one is better but it wouldnt have no effect on anything to do with the rims differences only when pushing the limits of the car with big power would the gtr one be benificial over the stagea one.
I honestly dont believe that staggered wheels would do much damage at all if any, as long as the heights of the wheels are all the same!
Actually come to think of it on the wheels i have on now ive got different width tyres and i have still had no problems
Nice Simon, nice,
I did like your old rims a lot, the mesh style really suited the car.
(yeah sorry Brad)
A rude awakening? We will all be jumping around like monkeys on smack, I'm sure... :no:
Nice Simon, nice,
(yeah sorry Brad)
its just weird seeing sunken wheels....maybe il get used to it
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
