I've got an exhaust temp gauge to fit and just wanted some opinions on the best location for the sensor, I've currently got a CES stainless split dump with HPC coating...so really didn't want to touch that., but then again I want the temperature sensor to actually be doing a proper job.
ive sen holes drilled in the rear housings of turbo's that ive imported from japan second hand. they seem to be putting them into the rear housing of the turbo's...
now i would like to add to this question as i've recently fitted one to mine. and put it down in the merging part of the front pipe.
what tempature ranges are good?
they tell you if your running lean/righ etc right?
hi guys i'm still trying to figure the best spot as well, but i really think that your reason for having the exhaust temp sensor is the determining factor i.e is it there just to keep an eye on things, are you checking individual cylinder temps (sensor in every exhaust outlet in your manifold) are you looking to run leaner than 14.7:1 and want to keep your exhaust valves intact?
my turbo had a 1/8 bsp fitting (from memory) just after the flanges from manifold to turbo and I think thats a pretty good spot as your can get an average idea of what you cylinder temps are and the heat that your turbo is copping?
My thoughts on the matter,
cheers Matt.
Exhaust temps are an INDICATOR of rich/lean - if you want to know HOW rich/lean then invest in a wide band O2 kit.
Pyrometer will measure (obviously) temps which are thermally loading the pistons, valves, manifold and turbocharger. All of them have thermal limits.
There are good reasons for inserting the thermocouple into the manifold pre-turbo, but generally it is too difficult/not practical to muck around welding into cast manifolds or a fabricated manifold collector. A disintegrating sensor getting blasted into a turbine would not end happily...
A turbocharger WILL see a temperature reduction across the turbine (energy transferred to the turbine to drive the compressor), so basically if you want any meaningful indicator of thermal loading then mount it as close as practical to your turbine discharge. ie. in the dump pipe.
FWIW, I'm seeing 500-650 with general running about. Closed loop operation about 700, and with extended higher rpm, aggressive throttle openings and boost up to 750.
Edited by Dale FZ1
oh so where i have it is rather pointless. and i know my afr's are well below 10.
not to worry really. fuel pressure i have also which i didnt think i would really need also.
well the standard one is at the cat.. i would like to have it at the cat. before it so i can measure the temps and back off before it runs the cat into melting mode..
the standard one doesn't give you any temp readings though. it's just there to tell you two things. 1. your cat is overheating and 2. dont park on long grass.
it's a waste of time to buy a proper exhaust temp gauge and mount it there. you may as well check your EGTs with the back of your hand...
yeah the one in the cat is after the matrix and its called an after cat temp sensor as explained above to let you know theres a problem. temps at exhaust manifold upwards of 750oC at the cat around 300oC. EPA can measure temps before and after cat matrix to tell if its still intact.
I really think the best spot is before the turbo. That doesn't mean that you have to weld anything, drill a hole in the turbine housing tap a thread into it, its cast there won't be a problem, just use grease to catch the swarf ( some thread repair guys have tiny vacuums....)
Matt
Edited by mattymagoo22
True from a technical perspective. As I said earlier, there is a temp differential across the turbine due to energy transfer into the rotor.
From a practical perspective, I'm happy with installing in the dump within a short distance of the turbine outlet. I may not have the best absolute reading, but it's not a bad indicator.
Unless I had the turbo off, and turbine housing removed or manifold off I'd not be interested in the possibility of sending metal shavings through the turbo.
This discussion is similar to "where is the best place to measure engine oil temps?" ; there are options, some better than others.
I have a GT2510 and it has a small bolt thingy just after the flanges from manifold to turbo. Anyone know what size it is? Would it be a good spot for a EGT sensor?
Edited by WilYawn
yeah thats the spot i was talking about and I'm pretty sure its 1/8th BSP pipe thread, there are pyro sensors that will screw in no probs. (don't ask me which but I've seen em and the turbo I bought had one in it but was not sold with the turbo)
the closer to the exhaust valve the better. combustion temps 750oC and up, tail pipe 100oC maybe , the heats got to go somewhere, just my opinion.
It is in no way difficult to tap a thread in the spot pointed out on the above photo( it may already be there just has a plug in it), or in the collector of your standard cast manifold, and when done properly the risk of metal filings 'damaging' the turbine is far from high, however I wouldn't recommend it for the mechanically inept as your concerns may well be realised if done incorrectly.
cheers Matt.
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
