as topic state i have a hybrid fmic and about to install bleed valve. there is no hose going into the intercooler piping. did a search and ppl say they drilled a nipple into there intercooler piping. dont really want to do this. there must be a way to hook it up. any one done this b4? got any pics?
Theres a vac line coming from the throttle body down and under your intake pipe where your bov sits going to your carbon canistor, put a 3 way thingo (cant remember wtf they're called) and then go to your bleed valve there... or use the search button..
actually you need to make one up, do not put vacume to the wastgate, as the diaphram is not designed to work under vacume, it will get damaged. Best thing to do is to drill and tap the stock cast intake pipe, BEFORE the TB and put a screw in nipple into it. That is how i did mine, works well.
A nipple on the pipe would still have vacum?? woudlnt it?
Um... this doesn't make sense about the vacuume to the wastegate damaging the diaphram... doesn't the wastegate open and close on vacuume/boost pressure, isn't it designed like that from factory? And if you are right why does everyone that i've seen just run it from the vac hose, to the boost controller to the wastegate?
the hose that is supposed to go onto the intercooler piping is t-pieced into a hose that runs to where the intercooler pipe joins to the intake plenum if that makes sence. can i just join the bleed valve to that line. if that doesnt make sence ill get a pic later.
no as soon as boost pressure is released the spring forces the gate shut, there is no vacume on the setup, as the stock boost tap is placed before the TB. Introducing vacume to the diaphram can couse the diaphram to pull away from the shaft mounting plate thing, sorry can't remember the techincal name. If you do use a one way valve, ensure that it is placed before the tee peece bleed valve, otherwise you will get boost goign to the gate, and then it will stay open as it will still be under pressure.
the yellow line is the one that is supposed to be connected to the intercooler piping. if i put the bleed valve between the yellow line and the actuator i still dont see how it wont work because the standard boost control is hooked in there and why would the mechanic hook it up like that if its wrong.
As long as that hose has vacume pressure its the right one. Or am i wrong?
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
