Hey all,
just wanting to get my front bar and side mirrors touched up as theyre fading baaaad.
Not sure if taking it to somewhere like Jerry's would be very cost efficient as theyre only small jobs... some people are saying to DIY but ive honestly got NFI how, and id probably fk it up...
So any suggestions would be great
Cheers :laugh:
Edited by SKYLVIA
https://www.sau.com.au/forums/topic/155435-touch-ups/
it was like a late model sports one. NO.
Alot of people are not happy with jerrys prices but at the end of the day if he makes a mistake he is in my experience more than happy to fix it. Now im not saying 1k for a "touchup" is reasonable but jerry is usually quite flexible.
https://www.sau.com.au/forums/topic/155435-touch-ups/#findComment-2891949
Yeh he hasnt been bad to me, refunded the price of a paint detail coz there were swirls in my paint and now nearly 2 months on im going back to get the winsdscreen seal put in and the bonnet badge on for $0.
Was unhappy with some things but as you said stye he's happy to fix em up for you.
https://www.sau.com.au/forums/topic/155435-touch-ups/#findComment-2892614
first of all.....
Sounds preeeeeeeeetty queer andrew... :P
BAHAHAHAHHAHAHAH!
But i looked it up in yellow pages
The Touch Up Guys
Flag no.1
19 Grigg Pl Richardson ACT 2905
ph: 0412 697 686 Panel Beaters &/or Painters
Keyword: "Beaters"
Do 4 maori guys stand and direct you to a dark alley way?
https://www.sau.com.au/forums/topic/155435-touch-ups/#findComment-2895310
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
