Just sold the s15 know it is time to sell the GTR :laugh:
1992 R-32 SKYLINE
RB26DETT 2.6L TWIN TURBO MAN
ENGINE JUST REBUILT DONE 3000KM
HYPERFLOW BODY KIT
CARBON BONNET LIP
CAMELION PAINT
5 ZIGGEN RIMS
LEATHER INT.
GREADY GAUGES
GREADY TURBO TIMER
HKS BOOST CONTROLLER
TEIN COILOVERS
FORGED PISTONS
HI-FLOW TURBOS
HKS CAMS/CAM GEARS
GREADY INTAKE PLENUM
700CC INJECTORS
RE-LOCATED OIL FILTER
800X400 8 INCH CORE INTERCOOLER
FRONT MOUNT OIL COOLER
STAINLESSS PLUMBING
TWIN INTAKE
FRONT STRUT BRACE
JAPSPEC COMPUTER RETUNED
18-22PSI BOOST 334KW@WHEELS
COSECUTIVE 11SEC PASS AT EASTERN CREEK
XENON FRONT LIGHTS
NEW CLUTCH MASTER AND SLAVE CYLINDERS
+ MORE
EX-SHOW CAR COMPETED IN AUTO SALON
car is in great condition but hasn't been driven as i have just brought another house so i am selling of my cars
$30,000 ONO (no rego but can provide pink slip)
better pics on req but would rather you come have a look
stuart
Edited by stuartr32
https://www.sau.com.au/forums/topic/155438-r32-gtr-with-334kwwheels/
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
