for sale is my 86 hilux extra cab. it has a really short tray on it with big 3" roll bars
custom ford purlpe
sr20det
garret 600hp dual ball bearing turbo
3" exhaust
hilux lsd
supra 5 speed box
microtech ecu
microtech igniter module
autometer gauges
17" roh rims with good tread
pwr radiator and intercooler
blitz bov
malpassi fuel pressure regulator
carter lift pump
bosch fuel pump
1.5l surge tank
motor rebuilt only 4,500 kms ago
$ 25,000 spent conversion is mod plated
$ 16,000 ono
it will come with rego and a rwc
im also looking for either a modded r32 or a 180sx.
my mobile number is 0437 905 531
https://www.sau.com.au/forums/topic/155440-for-sale-86-toyota-hilux-qld/
  • 4 weeks later...
  • 1 month later...
