I have been really enjoying this site, lot's of good info. So I thought you guy may like to see some stuff I'm doing state side. We do not do a huge amount of RB stuff but, for some reason for the past month or so we have had 3 RB projects. Here it a "J" pipe I fabed for an R33 with a Internaly gated Garrett 3076R.
The jig I made to locate the factory DP location:
The tacked up "J" pipe
I expect someone will comment on the wastegate tube angle as it comes back into the “J”. I’m working on a better merge now. I also kicked the pipe closer to the block so it will work on left hand drive 240's
Edited by Overcenter
https://www.sau.com.au/forums/topic/155458-3076r-j-pipe/
Hi , good to see people fabricaring RB bit Stateside . Is that the ATP flange plate you used ?
Also what do you think of the idea of sectioning the waste gat vent pipe lengthwise (sort of sideways "U" shape) and welding it along the side of the main dump tube ? Possibly more compact .
Thoughts ? Cheers Adrian .
https://www.sau.com.au/forums/topic/155458-3076r-j-pipe/#findComment-2891316
Yep, its the ATP flange. I wanted to get the entery as far down stream as I could.
Thanks for the complements guys.
https://www.sau.com.au/forums/topic/155458-3076r-j-pipe/#findComment-2892506
looks the goods, maybe shortening the 2nd section of the WG pipe will allow you to move things up further to get a smoother integration of the WG gasses.
This is why we need a fabrication section on the forum
*looks at signature
Wink wink nudge nudge
https://www.sau.com.au/forums/topic/155458-3076r-j-pipe/#findComment-2892513
excellent work. You americans and your bling stainless. Cant stand stainless pipework, looks the shit for a few months then the heat kills it, it goes grey, loses its strength and looks. But very nice fab work.
https://www.sau.com.au/forums/topic/155458-3076r-j-pipe/#findComment-2892622
The cheap China stuff goes to hell fast. The Rath or Gibson 304L stuff we get here in the states fairs much better. Are drift cars 304L down pipes are still gold even after a season of abuse. On this years drift cars I'm staying with a 304L dump tube and 6061 T6 from the dump to the muffler. Time to shave some more weight out, I got last years S13 down to 2130 LBS.
https://www.sau.com.au/forums/topic/155458-3076r-j-pipe/#findComment-2892697
The thing I worry about with the ATP flange is that the wastegate "hole" is not flush with the actual housing. When the flapper is slightly open, it'll create huge turbulence as it backs up behind the "lip" of the flange.
My thoughts also..
However it 'may' be a good thing if the pressure within the scroll is blowing open the flap (boost drop), but bad if the wastegate is too small to pass the requried gas as not to creep boost.
https://www.sau.com.au/forums/topic/155458-3076r-j-pipe/#findComment-2894431
T6 as in ally pipe. What wall thickness do you use also?
How does that fair? With all the bumps and shocks from drifting or racing, it doesnt bend or distort maybe crack?
Edited by r33_racer
https://www.sau.com.au/forums/topic/155458-3076r-j-pipe/#findComment-2894847
The aluminum holds up well, we even have a few guys that drive it on the street. On the drift cars I expect it to get busted up a bit more, unlike the drag, circuit and street cars. At $15 bucks a bend let it, I just do not care its better than $45 per bend in 304L. I use .065” wall and like I said it holds up well
Also in regards to the ATP flange, yes it does cause turbulence. Any internally gated turbo is just a compromise.
https://www.sau.com.au/forums/topic/155458-3076r-j-pipe/#findComment-2895985
The XR6T 4ltr Ford Blokes over here have issues with their GT3540 internal gates overboosting, another bloke on this forum with his gt3540 int gate also has issues with over boosting on his 3ltr.
Creating more turbulence at the wastegate is only going to make boost creep worse, they need all the help they can get not to overboost, seperate wastegate pipe with a smooth merge. That being said I haven't seen the XR6T blokes running with split dumps, rather just the usual open mouth so possibly that is half the problem.
Have you enlarged the wastegate hole at all?
https://www.sau.com.au/forums/topic/155458-3076r-j-pipe/#findComment-2895998
*looks at signature
hmmmm. :happy:
https://www.sau.com.au/forums/topic/155458-3076r-j-pipe/#findComment-2896005
Well, to try to combat the turbulence created down stream where the wastegate enters I left a .250 lip along the leading edge of the pipe. This will create a low pressure area across the mouth of the wastegate pipe and help with the turbulence. He is only going to run 15-16 psi. At what boost level are the XR6T and running into issues? The wastegate hole has not been enlarged.
Honestly, I despise internally gated turbos, but it is a more cost effective alternative vs a new mani.
304 "L" bends range from $45-65 us, the 3" bend I used here was $55 retail and the 2" was $48 retail.
https://www.sau.com.au/forums/topic/155458-3076r-j-pipe/#findComment-2896027
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
