55 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I just bought a high flow turbo which I was told was a genuine bolt on job. Being fairly new to the scene I thought that bolt on meant it was pretty much a straight swap ie. no stuffing around with oil and water lines / fittings. Instead I get a turbo which isn't even close to being a straight swap. None of the stock oil/water lines match up and the turbo needs to be "clocked" so it matches up with the stock air inlet.
These are all questions I should have asked before I got the work done, isn't hindsight great.
Anyway, I just wanted to see what other peoples ideas of "bolt-on" were.
Cheers
https://www.sau.com.au/forums/topic/155503-whats-your-idea-of-a-bolt-on-turbo/
well bolt on is.. straight on no mods.. custom is doin something different to make it work..
when u have to get new lines or something like that u cant classify that as straight on.. ur mucking around...
Tis bolt on if your engine can handle the turbo upgrade..
a turbo that requires some bolting requirements
LoL..
Is the HKS GT-RS kit with the oil water lines and all fittings and shit.. is that classified as bolt on? cos everything is designed to fit like the turbo and oil n water lines in the kit?
Cheers
bought off who?
i class it as 1 that you attach with bolts, rather than with say, glue or zip-ties.
but seriously, i would class it as oil and water lines screwing straight in, even if the oil line has to have 1 of the fittings drilled out to let more oil through (e.g. a slide highflow). and most importantly that it bolts up to your manifold.
Bolt on = bolts onto the stock gear.
Manifold, dump, intake pipings
If you need to mod a oil/water line, big deal. Its really not that hard.
I wouldnt count oil lines depending on the type of turbo (covered further on)
As for the turbo being "clocked" what you do mean?
One of the housings rotated? If so, thats pretty much gonna happen on any turbo as no-one is going to get it perfect for your car
Also depends what types of turbos (as i said earlier) ie Bush --> Ball bearing and vice versa.
If thats the case where your changing from one type of turbo to another (and reason for the oil/water mods) then its a bit of buyer research aswell as the seller IMO.
Two way street on that one as an owner you should really take a little interest in what they are purchasing :(
Can you give more details?
Type of turbo you had, type of turbo you have change too? etc?
Would kinda help us to give you a better idea maybe :)
The product is a direct competitor with the GCG highflow. Stock turbo to ball bearing highflow.
It was explicitly stated that no modifications to the stock lines were required. The only change needed was to change the banjo bolts (not the entire fitting, just the threaded part) because the thread on the new core was different.
The reality is the oil and water lines need to be changed, the oil drain needs to be modified and the wastegate actuator needs to be modified. The fittings provided look like they are designed for rubber hoses and as such, are completely useless.
I personally wouldn't call this a bolt on affair.
Thanks for the input.
Edited by Ol_Mate
if that is the case then it isn't a high-flow, it is a whole new turbo. it obviously isn't using the stock housing, otherwise it would just bolt back up.
i'm not aware of any other high-flows that use ball bearing other than the GCG. i know slide's are a bush bearing and it needs the hole in the banjo line drilled out to let more oil in.
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
    • Glad it eventually came out Duncan!   I believe that might be 040. 044 is the inline pump, so has screw fittings in and out. 040 is more just drop it in fuel and the bottom is "open" (mesh) from my memory
    • well mate, while I hear your pain, turns out I don't feel it this time! Must have been a bastard of a job crammed into the boot The tank was very empty (probably pumped out, not dropped and drained because there were some fumes still) and in very good condition internally. I'm sure he never ran e85 in it I don't know what the hell Nissan's fuel tank engineers were thinking about their clipping system, this hanger was really hard to get moving but came out in the end All looks very good (as I'm starting to hopefully expect) and Matty was right it is an 023 (044) bosch which should be plenty for the injectors and turbo
    • Saturday 8th February 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Thursday 6th February 8pm. Supp Regs: TBC Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid  AASA General Speed licence or (Day license is $35.00 via the AASA Website) MA Licenses are no longer accepted by AASA https://aasa.com.au/ A helmet, long sleeve clothing and it is reccomended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs Above. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Entry Link >> https://www.sauvic.com.au/entry/deca/20250208 Entry List: 1. Martin Sullivan 2. Richard Hicks 3. Warren Clark 4. Luca Stamatescu 5. Tony Buckland 6. Min Chan 7.  8.  9. 10.  11. 12.   13. 14 15.  16.  17.  18.  19. 20.  21.  22.  23.  24.  25. 26.    Reserve list 1.  2.
