Ok, well plans have changed a little bit.
Im not doing a manual swap till next year at the sooooonest.
I just cant stomach tearing up a limited edition for some manual action.
Sooo. ill go to IPT and get a push button gear shift system for 500 bucks later this year, and start Gripping this bitch.
I need to work on my roots driving skills anyways, so ill do that for a while
plans int he next month are as follows
Suspension-
Footwerks coilovers (extra made garage) I had them on my 180, love them. Ive had cusco, tein, JIC, and i like them the best so im sticking with them.
Wheels-
I honestly havent decided. I found some 19 Inch VIennas for cheapo, but im not sure if i want to run something that big without aero.
so i might go to 17s and drop the f**k outta it.
not sure yet still.
Engine
Downpipe
Catback
Put my AVCR and SAFC in
Wideband
(supposedly 280 HP without tuning according to aussie guys)
other shit-
Puddle lights
Curtains
VIP table
HIDs
and a series 2 stagea grill with fogs.
but enough of the bulshit, heres the pictures of the stock stagea to start with
(i put in the flip out)
yer the only stagea people i know!!
https://www.sau.com.au/forums/topic/155513-stagea-from-japan/
I was stoked that the center console is color matched!!
Lol its the little touches like that and the suede door inserts taht just make this car Baller
Im used the cars that are pure function, this thing is awesome!
Yeah rally nice, you've never heard of SWAT?
Stagea
Web
for
Advanced
Tune
See signature, or this link:
http://6709.teacup.com/swat/bbs
It's great to finnally have an actual Japanese member on SAu!
Please also click on the Frapper link and add yourself in :no:
nothing better than a military man in uniform and one who drives a stag..... :) (love ya MrGTST) harhhhh...i mean .. :) ... i mean nice looking stagea you got there :) looks like my car has potential after all :)
well thanks for hte compliment
Im going to put my 17x8 and 17x9 advan 3 spokes on in a few hours with 215/45/17s all around.
adn i might test fit the SSR Viennas off my 180 for fitment as well
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
