Stagea From Japan!
yokotas13
 Share
Ok, well plans have changed a little bit.
Im not doing a manual swap till next year at the sooooonest.
I just cant stomach tearing up a limited edition for some manual action.
Sooo. ill go to IPT and get a push button gear shift system for 500 bucks later this year, and start Gripping this bitch.
I need to work on my roots driving skills anyways, so ill do that for a while
plans int he next month are as follows
Suspension-
Footwerks coilovers (extra made garage) I had them on my 180, love them. Ive had cusco, tein, JIC, and i like them the best so im sticking with them.
Wheels-
I honestly havent decided. I found some 19 Inch VIennas for cheapo, but im not sure if i want to run something that big without aero.
so i might go to 17s and drop the f**k outta it.
not sure yet still.
Engine
Downpipe
Catback
Put my AVCR and SAFC in
Wideband
(supposedly 280 HP without tuning according to aussie guys)
other shit-
Puddle lights
Curtains
VIP table
HIDs
and a series 2 stagea grill with fogs.
but enough of the bulshit, heres the pictures of the stock stagea to start with
(i put in the flip out)
yer the only stagea people i know!!
I was stoked that the center console is color matched!!
Lol its the little touches like that and the suede door inserts taht just make this car Baller
Im used the cars that are pure function, this thing is awesome!
nothing better than a military man in uniform and one who drives a stag..... :) (love ya MrGTST) harhhhh...i mean .. :) ... i mean nice looking stagea you got there :) looks like my car has potential after all :)
well thanks for hte compliment
Im going to put my 17x8 and 17x9 advan 3 spokes on in a few hours with 215/45/17s all around.
adn i might test fit the SSR Viennas off my 180 for fitment as well
 Share
    • Hey guys any recommendations for fitment for a stock 94 GTR R32  Want to order work meister s1 3p and would like a nice looking flush fitment. Plan to get MCA coilovers to set ride height etc. Just confused on offset, brake clearance etc.  Never purchased after market wheels so I'm a bit concerned since it's a long wait to order and I don't want to order the wrong specs.
    • Update: Done: -Running on 6 cylinders, one injector was gummed up. I made an injector tapper, bit of Teflon on the end of a metal rod.  That fixed the injector. Need to replace one injector plug, the fastener is broken. -Coolant bleed -Fixed 4WD warning light, bleed 4wd system -Fixed electrical problems: alarm, brake lights, various broken plugs  -Got all the parts ready to connect head drain. Head drain is fitted with a blocker atm Todo: -Fuel pump dead, Been cleaning out the tank, had a lot of tobacco looking stuff, think its OEM foam. Got a Walbro 460 to put in. Probably going to add a relay to give the pump a solid 13volts. Replacing all the fuel hoses, in tank etc. -Front drive shafts still not back on. Waiting on parts. Would like to buy some new ones, but probably going to patch these up for now -Replacing gas struts on back door. Waiting to be returned -Headlights need a polish/repair -Going to touch up the paint a little. -Clean up the interior -Connect up heater plumbing -Cosmetic stuff, powder coat replace rusty parts, replace rusty bolts, wiper blades, silicon missing rubber -A million other things
    • Don't do this unless it never gets hot where you are.
    • Upgrade time. Been a long time coming, but I was able to get my GTR to a reputable builder in the States. List of upgrade parts below: RB30 (Sourced from Australia) PRP RB30 timing belt kit with all options Nitto pistons Nitto I beam rods Nitto oil pump King engine bearings New RB26 Head (Grabbed during Heritage run) Kelford 272 cams mild lift Supertech intake and exhaust valves over sized Nitto Head gasket Greddy Oil Pan Sump GKtech fan blade and adapter Koyo Radiator Borg Warner S362 SXE 6boost turbo manifold T4 divided  Turbosmart wastegate Pro-gate 50 lite ID1340x injectors Radium external surge tank Walbro 450 fuel pumps x2   All Parts in hand and awaiting my turn in line at the shop!
