Manual/Auto: Auto
Speedo Reading: 219000 (only 2000 on new motor)
Asking Price: $6000
Pictures: Will be up soon
Hi guys,
The time has come, I need money to pay back loans.
Car details:
-1987 Bt-1 Turbo
-White
-No major rust, only surface
-straight body
-Auto
-Cooler
Rebuild work only done 2000km/s ago
-Recoed head with crow cam (specs on request), ported
-Bottom end
- Oversized bore (only because it was out)
- Ceramic Coated Pistons
- Balanced Crank
- Rebuilt Oil Pump
- All contact faces were refaced e.g. exhurst manifold, inlet manifold etc
- The usual rings, bearing etc
- have all papers
-Injectors were recoed in March
-Radiator resoldered and in January
-LSD Diff
-Big Cooler
-HKS Super BOV
-QLD Rego till December
-A few other little things
Has custom interior
- Door cards gray velour with purple flames
- Seats front and rear (calais) gray velour with purple trimming
- head rests are all purple
CAR SOLD AS IS
*Car hasn't been tuned by any workshop so very under powered and running a little rough at the moment.
*Tranny needs a good service
*front suspention needs a look at (it's wearing the outer lip of the front passangers tire)
Sully
    • Nissan/Pitwork is fine stuff. HKS is just marketing wank. I personally wouldn't do the idler if it is already new. If it looks and feels fine, it is fine. But as D says - it's cheap to add it to the job. The water pump ditto. Even more so. If it show no signs of problems, then it is nearly new - leave it.
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
