Hey guys,
I've noticed that the rear drivers seat squeaks.
Its the shoulder of the seat rubbing against the wall of the car - make sense? :)
This is also an incovnience when I have the ladies in the back seat, and I haven't got the "..its the leather", excuse to fall back on. :woot::)
I'm thinking it may be a tad loose, but then again I'm ripping it against the wall to see what's behind it.
Is there anyway to release/re-tighten the rear seats?
https://www.sau.com.au/forums/topic/155557-squeaky-seats/
The rear seat shouldn't press against the side too much. Most of the time they are....this is because the big plastic cover with the built in arm rest is loose. The press in clips that are on the back of the cover pop out of the metal holes in the car shell. This is one area nissan stuffed up, the holes are just a little bit too big. You can try pressing the cover back on, but it will likely only pop off again. I tried several different methods of making the hole in the metal smaller and/or making the plastic clip that goes in the hole bigger. The only thing that has worked so far is to use a drill and pop rivets on the edge of the hole thus making the hole smaller. This means that the plastic clip at the back of the cover fits in a lot tighter and won't pop off.
Personally I prefer a tight fit, but I am also keen to pop off......then again I am not a cover.
PS If any of you 'gun' metal workers out there know of a better method of fixing this, let us all know.
https://www.sau.com.au/forums/topic/155557-squeaky-seats/#findComment-2895494
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
    • 😂 thanks guys. The diagram i had did not have the breather on it at all. Much appreciated.
    • Geez, engineers fees have definitely gone up. Mine back 2007 cost me all of $300. Mind you, I had to go back to him a few times to get him to write the correct things on the report after he'd inspected it. Things like wrong exhaust size, wrong wheel sizes, etc etc.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
