Dave - So from what you saying, the cap can be exceeded? I thought a cap was exactly that?
It depends whether you have a soft cap or a hard cap. A soft cap will allow you to go over the cap limit and you then pay for each call as per the call rate charges of the cap plan. A hard cap will allow a certain amount over the cap limit and then calling out will be barred. If you are going for a cap plan, make sure it is a soft cap (most of them are)
I am on a $59 optus cap which gives me $350 of credit...and a dopod 838 (which is same as the i-mate jasjam)
  • Replies 48
working for telstra i can tell u they are the best. they may not have the cheapest plans out but if u bundle it with your homephone u reep massive benefits.....and the best thing is...when u take up any business plans....all call rates are 11cents for 30 seconds.......try beat that!! and all u need is a ABN....u could even use Telstras which can be found on google :(
i wont even mention how Next G is gonna destroy all other competitors........and i wonder how everyone is gonna cope with CDMA when it gets phased out....they all gonna have to turn to telstra.....and dont worry if ur on CDMA with telstra we are upgrading everyone to the Next G network with a brand new phone for FREE!
Edited by anDru
working for telstra i can tell u they are the best. they may not have the cheapest plans out but if u bundle it with your homephone u reep massive benefits.....and the best thing is...when u take up any business plans....all call rates are 11cents for 30 seconds.......try beat that!! and all u need is a ABN....u could even use Telstras which can be found on google :huh:
word!
which department are you at?
Thanks for all the info guys and the links too. Time to make a decision on it. Optus has the blackberry on a good plan that I like. Telstra has the coverage and the history and Vodafone also has some good deals.
Cheers all :huh:
working for telstra i can tell u they are the best. they may not have the cheapest plans out but if u bundle it with your homephone u reep massive benefits.....and the best thing is...when u take up any business plans....all call rates are 11cents for 30 seconds.......try beat that!! and all u need is a ABN....u could even use Telstras which can be found on google :mellow:
lol dont get too excited. Optus has got some awesome stuff in their pipeline, when that is released it'll be just as good as Telstra's service.
3G is way overdue as it is. Some one needs to crack the whip cause it should have been done by now.
But yeah once Telstra goes 3G, everyone else is fcuked
whats Optus got cummin up? im pretty well imformed when it comes to Optus/Telstra how come i havnt heard anything :S
no it wont. optus is going"sole" in their 3G coverage in some up-coming areas (ie. pissing off Voda). it wont be of any competition to telstra's NextG network.
telstra has gone 3G for quite a sometime now.... yes, both WCDMA2100 and WCDMA850
where is telstra WCDMA2100?
Optus is 2100 and so is Hutch. Telstra were the only ones to go 850...make that the world, (expcet one carrier in the US)
I wasnt aware of any 2100 real deplyments by Telstra. I'm intrested as it relates to somthing I'm working on over the next few months.
telstra is the half owner of the hutch 3G network at the moment (joint partnership). telstra is currently budiling the 3G network for Hutch nation-wide. when there is no hutch 3G coverage, you get put on telstra GSM900 network.
optus and voda is the other partnership in the other WCDMA2100 world.
what will you be doing over the next few months?
not sure will contact my hutch guys and talk with telstra later.
I'm doing stuff which I cant talk about, sorry mate.
  • 3 months later...
I've got some Nokia thing that bounces when you drop it (tried and true) on a $0 a month plan courtesy of work :teehee:
Hope I was of help Saff :D
Check the thread date! :laughing-smiley-014:
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
