Gday i'm just about to change my Gearbox oil... thinking of going with Redline lightweight Shockproof. Just got car imported and dunno if stock oil is in it still, so thought I'd change it anyway. (car has done 75,000km)
Just few questions....
Should i go easy for first 1000km after change?
Most people use this if they have gearbox crunching i have read so is it ok to use it if u dont have gear crunchin etc? Im guessing its ok?
Also is Redline way to go? I dont have noises so maybe something cheaper or i am i best off going all out?
P.S. Did try a search guys... sorry if it has been covered!
Thanks
https://www.sau.com.au/forums/topic/155564-gear-box-oil/
make sure you use the Super Lightweight Shockproof (its a 75w90)
the lightweight shockproof (75w140) is too heavy and makes it hard to put into gears when warmed up
and i dont believe the oil needs to be run in but it cant hurt behaving for 100-200 K's
EDIT: Redline is a very good way to go top stuff! but me personally would go Royal Purple MaxGear
and yes i would go all out the better the oil... the less wear... the longer and healthier the gearbox lives
RellikZephyr
Edited by RellikZephyr
https://www.sau.com.au/forums/topic/155564-gear-box-oil/#findComment-2893474
thanks jjjDavey, read that sticky was good info! just had those couple other questions aswel on mine... Mine doesnt crunch. Drives well, just thought new oil.... why not!
So anyone else think castrol VMX80 is best suitable for my gearbox? doesnt feel worn or old i just want it to last as long as possible!
Edited by bluey33
https://www.sau.com.au/forums/topic/155564-gear-box-oil/#findComment-2894515
yes Royal Purple i would say is a better product than Redline
i have also heard that thing about Redline with newer gearboxs
i would say that Royal Purple is as good as Redline in the smoothness of the gearbox BUT Royal Purple has this thing they called "Synerlec" which claims to Polish the metal as it lubricates and i have a test thing they done with it and it did exactly that didnt wear at all but polished the metal (can post it up if you want)
it also has a friction additive in it called "Synslide"
Sorry for the blatent plug but just stating why its my opinion that Royal Purple is better
Hope it helps
RellikZephyr
https://www.sau.com.au/forums/topic/155564-gear-box-oil/#findComment-2895245
Apparently Redline Lightweight Shockproof isnt designed for synchro gearboxes as it doesnt allow your synchros to mesh properly. Also it supposedly has a short lifespan as it is designed for racing applications. I had it in my gearbox but recently drained it out and put in Redline MT90 (which is designed for synchro 'boxes). The shifting is a bit notchier with the MT90 however. If your not getting any crunching from your gearbox I wouldnt use any of the shockproof oils.
https://www.sau.com.au/forums/topic/155564-gear-box-oil/#findComment-2895594
No No dont be sorry i asked the questions and expect answers with opinions!
i just read about it on there site... seems good enough!
Do u know where i can get it? local autobahn/repco etc?
yeah mate i think you can hit up your local autobarn to order some in
Also PM sent with the test thing on the oil
Cheers
RellikZephyr
https://www.sau.com.au/forums/topic/155564-gear-box-oil/#findComment-2895682
