ok i've started with laguna seca, sepang, suzuka, tsukuba, silverstone, nurburgring, brands hatch.
montegi and fuji wont come up (not a good image)
can someone suggest any other quality world circuits i can look at???
yes im bored watching the clock slowly tick by.......
https://www.sau.com.au/forums/topic/155584-racing-circuits-on-google-earth/
Stop me if you have seen this one before....
Not exactly a world circuit, but seeing as the project we are doing is in Geraldton and there is a prospect of my going to site for an extended period, I was having a look around Geraldton on GoogleEarth.. to the east of the airport in Gerro there is a dirt oval and a tarmac track O_o
I also found a burnout in a carpark in Geraldton that someone posted in GoogleEarth *smirk*
  iz32 said:
hahah... yer umm quality track that!
C'mon it is alright & the WASCC put in a big effort to keep competitors happy. Kolb is a bundle of fun as is Shell.
Anyway, you could try the likes of Laguna Seca, try finding the old Surfers Paradise circuit, maybe Imola, Monza som eof the defunct GP circuits. How about Donington?
You could post the images if you'd like.
Edited by djr81
  iz32 said:
stumbled across this funky blue thing too
Whats the funky blue thing? Looks like a massive sports stadium. Find some ground level pics :)
Edited by Jordan
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
