Hey all,
Going off another request from a fellow SAU R34GTT Member, I've helped to source a supplier who is willing to do us a deal on R34GTR Rear Spoilers. Unlike my other group buys on Fibreglass / Carbon items, the supplier is local (SRS Auto)
Anyways; here's the product description:
R34GTR OEM Rear Spoiler (copy)
* 4 piece construction (2 stands, 2 wings)
* Bottom wing and stands made from FG
* Top Wing Blade made from CF
* Top Wing Blade Adjustable
Pricing:
Each unit retails for $495.00 (incl. GST) + Freight (pickup from Sydney is fine)
If we get 5 orders; I've been advised that a 10% discount will follow so you're looking at $465.00 each
Delivery:
I have no idea how i'm going to go about sending spoilers around the country if this happens to go ahead but I will reserve this bit to a PER APPLICATION basis. Things like packaging, insurance and all that will most definitely be a requirement I would say.
Photos:
None as of yet, but I have requested them in high-definition. Will post as soon as they are available.
Lead Time:
I've been told that they will have a 5 week lead time on these so if you're keen; it will be payment followed by 5 weeks before the the wing hits Sydney (from wherever the hell they get made).
  • Replies 42
Posted Images
All depends on whether the GTR wing bolts straight onto the GTT wing... I've been told that this is an exact copy of the GTR wing even down to the bolt measurements.
Hmm, I'm thinking of a flat-bootlid for my R33, and putting this wing on the back. I have seen it done with a GTT wing but I admit it looked a little small.
Then I can get the R34 GT-R front end conversion from Japan.. ooh yeah, then I'll pick up a cheap R32 RB26...
How much are R34 GT-R's lately, Might be cheaper :)
What do you guys think it will look like on an R32? Or would a twin blade aluminium one look better. I'm hopeless with these things :)
has anyone ever come across a photo of this GTR wing on the back of a 4 door R34? (can they post it up if they have)
I have a carbon R34 rear wing. Top blade is carbon, so are the end caps, as are the 2 support uprights.
6 pieces in total
I think the support uprights are longer and can not see any join in the carbon mat.
excellent quality....made in Japan and imported by me....but cost me more than twice the price of this group buy.
If anyone in Brisbane is interested in having a looking...PM me.
6 pieces in total
Can you post up some photos?
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
