  • Replies 113
Yeah I agree with ya dezz before my mate installed his i saw the piping and it very minimal. Could that be why his not experiencing noticeable lag??? Car runs so much better on hot days now and his got the stock ecu and not running rich or anything like that.
These things are sweet :( My mate has one on his R33 his kept his car pretty original with not even upping the boost and no obvious extra lag is seen which is surprising due to the size of the piping.
Any chance you have some pics of it fitted to your mates car?? i really really need some more pics.
Cheers
Some info.
I have seen these and other coolers fitted to R33's where the owner said they had to cut the front bar a fair bit and they were almost all mounted incorrectly.
Basically there are 2 main things you can do to get the pipe (and the whole thing) to sit higher. One is to mount the cooler on a slight angle, bottom more to the rear of the car. The other is to use a rubber mallet to bash the bits of the radiator support panel that stick out back a little. I moved mine up about 3 cm just that (was an R34 though).
Also there are two mounting holes for the brackets that go on the top of the cooler. Some people use the lower one when you need to use the higher one. Need to relocate the horn.
This bracket is the only one that is not attached to the pipes. I think I have the R33 one lying around somewhere.
So do you think that the silver r33 on the 1st page has just mounted his up all wrong?? It dosent look very good at all which is why i need pics to confirm exactly what it looks like when its mounted up correctly.
Mine was mounted right up as Abo Bob said and I did have to move the horn but at the same time the front bar did have to get trimmed a fair bit to fit it. Reo bar was fine.
Im sorry mate been really busy I have some pics on my phone but cant hook it up to the comp at work. If I get home before dark ill borrow my sisters camera and take some photos for you.
Chris
Chris
No worries mate, any pics would be really helpfull :P
Thanks alot
Jason
He might prefer it that way.
Suffice to say it can be mounted higher. Don't worry.
Yea it sounds like your right, ill problly order one soon, just going to wait for alphanumeric to post up some good pics and if i like what i see ill order one asap.
Cheers for your help mate.
thought every says to keep away from sharp bends in the piping. beats drilling holes in your car i guess. i have the hybrid on my car but not happy wit drillin out holes. should have got 1 of these.
If the bends are nice and smooth it shouldnt disrupt airflow at all as it will still have a smooth path to follow, if it had sharp square bends then it would disrupt airflow quite a bit.
Thats the exact reason ive been looking at the blitz lm fmic, i dont want to be drilling holes and cutting fans blades just to fit a fmic.
Edited by nizmo_freek
heres some pics, haven't had the guts to start hacking the front bar up yet
Finally some decent pics :) thanks alot mate, so how low does that bottom return pipe actually sit? from the pics it looks like it sits a little low, is there any chance you could put the camera under the fron of the car and take a pic, i would like to see how low the bottom pipe sits compared to the bottom of the radiator support bar, that looks awsome tho mate, very tidy.
It is actually pretty easy to cut the front bar and bumper, on my old r32 i used a craft knife to cut the front bumper, you can cut about half way into the front bumper then bend the peice that you have cut and because its plasic it will just snapp off really cleanley, also dont cut to much off on the 1st go, just cut a little bit off at a time and then keep trial fitting it until it fits nicely. The front reinforcement bar is a bit harder, on my old car i just used an angle grinder which works fine, i would just suggest cutting little peices out at a time until it fits,just make sure you paint were you have cut or it will rust, Is there any chance you could post up a pic of the front bumper on once you have cut it to fit?
Anyway thanks again mate, really appreciate the pics.:)
Cheers :)
LOL its not the fading that makes it look ugly
Lol yea i wouldnt even bother painting the blitz logo on there, Looks to "fast and the furious" in my opinion, no offence.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
    • I might have gone a little more South Efrican.  But this is off topic.   😍😍 FD 😍😍
    • I think you might have skipped a whole vowel sounds there C.
