  • Replies 113
Just happened to stumble across this thread - better late than never though...
The silver 33 on the first page is my car and yes it's a genuine Blitz LM FMIC.
Admittedly, I've always thought my FMIC sat a little low, but I've never given it more thought as I personally don't mind the way it looks and as my car isn't particularly low, I vary rarely scrape the return pipe (only done it a couple of times when I wasn't thinking...very minor).
I did need to relocate the horn to accomodate the mounting bracket and the cooler is mounted directly to the mounting bracket, so I'm not sure how it's possible to mount it any higher (other than angling the bottom of the FMIC towards the rear of the car). Perhaps I was supplied with the incorrect mounting bracket...
Otherwise, my setup looked very similar to the pics posted by Ol Mate above.
here ya go
:) cheers mate, would you be able to get the same pic but from the front of the car looking up at the return pipe and the radiator support bar??sorry to be a pain, If you cant be bothered thats ok lol :)
The only pic i really need now is a pic of the front of the car with the bumper on, if you could post some up when yourve got it all finished that would be awsome.
Cheers
This is the exact reason i need some decent pics, some people say that yours is mounted wrong (no offence) and that theirs dosent sit anywere near as low as yours, then others say yours is mounted rite and looks just like theirs, so in a way im getting two different stories, which is making it very hard to decide if i should get one or not, hence why i need pics.:)
Edited by nizmo_freek
coolers were not meant to be this hard ey?
Lol :) i know what you mean, but when your paying $1080 just for a cooler you want to know exactlly what your buying before you buy it lol
Sorry, but I must be missing the issue....I've shown you and sent you pics of the kit fitted on 2 different R33's (mine and Justin's) and it is CLEARLY NOT below the front bar on either of them.
I think you're making your own decision harder than it has to be.
Nizmo Freek, it's simple...
Obviously the kit can be made to sit higher than the way it appears on my car. Dezz's pic above is a perfect example - don't ask me how he did it though (unless his mounting bracket is different to the one I received - I bought mine brand new 3 years ago, so perhaps the bracket has been revised, or more likely I've got the incorrect bracket or done something incorrect when installing).
Without going to the trouble of pulling my front bar off (don't ask, I'd love to help, but I won't do it), I think you've got about as much info as you're going to get to help with your decision.
If you're still worried about the return pipe being too low or you're considering substantially lowering your car, then perhaps you should consider a different FMIC.
Im not one of those people that just says "she'll be right mate", i would rather know exactlly what im buying, ive just had a look at my car to compare it with "Ol_Mate's" pics and it dosent look like it will sit below the bumper.
Maybe i am making this decision hard, but i would rather know what its going to look like before i buy it instead of just buying it without knowing.
The kit does come with a 33 and a 34 mounting bracket, the only way I can see that ECR033 could mount is any lower than mine or Justin's is if he used the R34 bracket, and in saying that I don't know for sure that using the 34 bracket would make it sit lower...I'm just saying thats 1 possibility.
Everything lines up, so I guess we can cross the wrong bracket off the list then...
I didn't do any bashing as such though - just fitted it straight on as is. Either that, or I stuffed up something somewhere (doubt it though, as again i'm guessing nothing would line up properly).
Regardless, it's done the job the way it is for the last 3 years - no reason to change anything now :D
I think the set up is this way it's because it is meant mainly for low mount turbos, instead of having the pipes circling all over the engine bay this method is better, however if you change into top mount, it'll be a........ headache...
with regards to the blitz logo, It was already on it when I purchase...
I'm not sure what to do atm, I'm going to change to forward facing plenum and topmount, the exit of the pipe went back to the left of the car.. which i think requires snake shaped pipings ><
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not!
    • So the other thing I got sorted over the weekend was Z1 oil catch can install. https://www.z1motorsports.com/z1-products/z1-motorsports/z1-q50-q60-30t-baffled-oil-catch-can-kit-p-23546.html It was a good kit, most importantly it came with preformed silicone hoses in the right shapes rather than trying to bend/join regular straight rubber hose. It did come with crappy spring clamps not proper hose clamps so I ditched them On the down side, it is made for LHD cars and RHD cars have the main ECU harness running straight through that location, I ended up bending 2 mounting brackets so the loom is up against the brake master cylinder compartment wall to make room for it....otherwise everything fit without modification Intercoolers off on both sides, but there was enough room to get everything done without disconnecting (and therefore having to re-bleed) the coolant lines. Each is mounted with 4x 12mm headed bolts, plus in and out side hose clamps (7mm headed, nice) and 3 electrical connectors on the navigator's side which were a real pain to undo (probably for the first time in 13 years).   Also one of the mounting bolts on the driver's side was cross threaded, thanks Infiniti/Nissan workshop mechanics. On the navigator's side, the catch can plumbs into the factory hose that goes from the cam cover PCV back to the intake.  This is the 2 new hoses in place. All simples and direct fit On driver's side, there is a bracket provided that mounts to the throttle body, they even provide slightly longer bolts to allow for the bracket thickness which is nice (although, they don't have captive washers like the factory bolts of course) In that pic the main loom brackets are not in place, once I had "adjusted" them across it now sits up against the panel and just clears the OCC The remaining problem with this is emptying it; currently you have to remove the 3x m4 bolts that hold it to the bracket and both banjos to remove it (probably dropping the banjo washers at the same time) pull it apart to empty then replace. I do have some fittings coming for a remote drain from underneath that will also add a little capacity...it is very small and will need to be emptied every oil change to be sure.
    • Noise sounds to me could be either wheel bearing related (have had similar from bearings going) or that tail shaft is still loose. Or something like a heat shield touching the tail shaft.
    • You wouldn't get away with saying the opposite, if you were there.
    • Do some wool fluff testing on the vents
