  • 3 weeks later...
  • Replies 113
Well i said i would post up some pics when i received the blitz lm fmic and got it all fitted so here they are, im very happy with it, was very easy to fit, everything bolted up perfect, had to cut the bottom of the reo bar a tiny bit but didnt even have to relocate the horns, the hardest part was cutting the front bumper, i wanted to get the bumper sitting flush with the cooler so it would get maxium airflow (if it had gaps around the cooler some of the air would obviously escape around that area instead of going through the cooler) this took lots and lots of cutting and trial fitting but in the end i think it looks great, and the best part is you cant see the pipe running underneath the cooler which i was concernd about.
Thanks to eveyone that took the time to read my thread and give me some advice,tips and post up pics, your help was awsome :)
Heres the pics:
I still have to work out were to put my plate as it covers some of the cooler and dosent look to good, also a big thanks to nengun for getting it to me so fast and hassel free.
Cheers
Jason
Edited by nizmo_freek
thats nice!!!! how much boost u running?? is it still running off the stock ecu?? hows the car feel now???
Cheers :stupid:, its still running the standard boost so around 9psi thanks to the exhaust (still need to get a dump/front pipe) ,and yes still running the stock ecu, the car seems to feel a little quicker in the midrange and up high but not by much,i can feel more lag when i hit the next gear but its nothing to complain about, it does seem alot better on hot days ,the car used to feel very sluggish when it was hot so i am very pleased with it :happy:
That's heaps nice mate.. mind if I ask how much it set you back?
It cost me $1135 nzd deleivered from nengun, that will probally sound very expensive comapred to the cheaper chinese made kits but in my opinion it was worth it!
Thanks for the comments :stupid:
i want to stick one of these on my stagea,(anyone got one on there stagea)not real keen on cutting anything & i'm lead to believe you can use existing piping holes & with a dayz bar hopefully no chopping there either.
Just get a Hybrid off EBay for $600-700 and put this mess behind you... Or you could get a trust kit off the trader section. I hear they are quite fantastic
hardly im a dealer for both and the BLITZ is a better kit than the trust and hybrid, both those kit reheat the piping as it crosses the radiator and they also have noticeably more throttle lag than the blitz. We also see lower intake temps with the blitz for those reasons.
  • 8 months later...
Sorry to bring up a thread from so long ago but im about to install one of these kits real soon on my series 1 r33
I've found plenty of peoples pics of there intercoolers mounted but i would love to see how much or preferably how little people have had to chop up there series 1 reo bars.
and what also seems very odd is i would asume most of you have used the supplied brackets yet many of the coolers are sitting much higher / lower on certain peoples cars. (how obvious the return pipe underneither is)
Cheers
Camden
Cheers
Camden
you cant see the return pipe if fitted correctley. full rrp is $1499 @ autobarn but shop around. Auto-concepts is the new AUSTRALIAN distributor and will match prices.
Buying ones not a prob i've already scored a new kit for $950 but im just trying to get myself sorted for the install whilst i wait for its arrival from japan.... was a really silly time of year to expect something to internationally frieghted... but the exchange rate was good at the time.
like I posted before im real keen on seeing how people have gone about moding the reo bar. for instance has it just been the lower section removed or has the very top needed to have a section notched out etc etc. Im certainlly sure that there are a hell of a lot of ppl on here who have just removed there reo all together which really doesnt flick my switch. I still want to have some crash protection and kind of like my front bar sitting flush with the lights :thumbsup:
I did mine in a day. You need to cut away about 20 mm from the underside of the reo bar. You cut both sides of the bar, making a strait edge instead of a concave. You need a grinder. As for the front bar, use a Dremel multi pro to cut out all other platic away. Measure once cut twice. :thumbsup:. You may need help to make it easier. Good cooler overall.
i used to have the blitz lm kit on my 33 gtst s2 :thumbsup: ive got a reo bar pre-chopped and ready to go if u want :) ??
im in melb 2
obviously there were differences in front bar design between series 1 and 2 but considering we are talking about a reo that has been chopped up a bit would a s2 reo work on my s1 ppl? i guess as long as the bolt on points didnt change on the chassis rails and the front bar curve wasnt to far difference this might work out?
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
