Hi guys, my mods are as stated in my sig. Recently i had my safcII apparently 'tuned' and i would have assumed that in the higher revs especially, reffering to high throttle mode, that the correction would be made to make the car run leaner rather than richer. I found my car was hitting a fuel cut or something at around 10psi on cold nights which never happened before. So i checked the setting of high throttle and this is what i found.
1400 -3%
1600 -16%
2200 0%
2400 -1%
3400 +3%
4000 +11%
4600 +13%
5200 +17%
5800 +6%
6400 +16%
7000 +10%
7600 +10%
Now would this explain why i am hitting this fuel cut? cos the ecu now thinks its getting even more air than it rwally is?? Unfortunatley the 'tuner' never provided me with afr's or anything but you would assume with the mods i have and standard management that the car would already be runnign hella rich... like 300 km's per tank (fairly heavy throttle at times though :) ) Do these settings seem right for the mods i have? - i would have expected (-) correction in th higher revs...
https://www.sau.com.au/forums/topic/155622-safc-owners/
hey mate below are my settings if it helps. mods are in my sig also
4000 0%
4600 -1%
5200 -6%
5800 -10%
6400 -10%
7000 -10%
7600 -11%
also below in my sig is my dyno sheet and my a/f ratios
Edited by r33madd
https://www.sau.com.au/forums/topic/155622-safc-owners/#findComment-2894837
4000 0%
4600 -1%
5200 -6%
5800 -10%
6400 -10%
7000 -10%
7600 -11%
See thats what i mean, you are having fuel taken out whilst mine is being put in!! i rekon the guy screwed me over- i put the seetings back to 0 correction and i reckon the car pulls heaps better.
https://www.sau.com.au/forums/topic/155622-safc-owners/#findComment-2894843
Ur correction setting are all over the place, im assuming ur stock gyno graph is not smooth as well. This would indicate in my limited opinion that there are some other issues with the cars performance and ur tuner has just tried to band aid it by tuing the safc. I would get it soreted first with no safc corrections then tune it again. Should have a fairly smooth curve for a skyline. what conncernes me is the correctiosn u have at low rpm before 400rm, also seems like he has added fuel? which is unusalus for a r33 unless there are other issues
https://www.sau.com.au/forums/topic/155622-safc-owners/#findComment-2896108
Personally i think the guy had little to know idea what he was doin, cos the power curve before the tune was quite smooth and the one after was all over the shop. I'm gonna get a different tuner to look at it, then go back to where i originally got it done and see just what the hell is going on - cos i feel ripped off. I wound the corrections back to zero and in reckon the car pulls better! i will not be going back to these people...
https://www.sau.com.au/forums/topic/155622-safc-owners/#findComment-2896161
  • 1 month later...
I have had the standard tale of wow, i got a hiflow turbo, cheep. bolted on and heaps a boost but a big miss.....
installed SAFC, miss started to lessen but still present @4000 rpm...reduced the fuel..
chased that down to bad coil, replaced it and taped all ciols.
big miss @4000 gone, but small miss @5000....
booked in for dyno soon but very interested to know what others SAFC are running@
where is your Hi / Low % set?
https://www.sau.com.au/forums/topic/155622-safc-owners/#findComment-3035790
previously my settings were all + across the rev range, never had the - correction. Until recently a tuner made it all to - corrections. On a cold night , pushing it a little, below 5k revs, my knock was 111 :S
Where is your Hi / low throttle position set?
What was the max -XX% set and and at what rev?
Sorry to be a pain but i am interested in this.
https://www.sau.com.au/forums/topic/155622-safc-owners/#findComment-3037395
the settings you posted are a long long long long way off. The settings r33 mad posted look like a good default setup.
I currently run these settings from memory:
2000 -5
3000 -5
4000 0
4500 -2
5000 -9
5500 -13
6000 -11
6500 -14
I also have an SITC which is dialed in to give an extra 5 clicks of timing at 4000 rpm to help clear out the R&R. however it is still noticeable on cooler evenings.
https://www.sau.com.au/forums/topic/155622-safc-owners/#findComment-3037628
2000 -5
3000 -5
4000 0
4500 -2
5000 -9
5500 -13
6000 -11
6500 -14
Yeh i know they were thats why i was so confused about the whole thing. Anyway that was a while ago, turns out the the 02 sensor and the fuel pump were both pretty screwed when the first 'tuner' so he called himself, tried to tune it, which is why it was so all over the place and had positive correction. I took it elsewhere to get checked out and got a new pump and sensor, with a re-tune of the safc and it all runs good now. simular correction to above.
https://www.sau.com.au/forums/topic/155622-safc-owners/#findComment-3037889
where on earth did you manage to get an SITC??? i've kept an eye out for over a year and have yet to find one for sale!!!!
https://www.sau.com.au/forums/topic/155622-safc-owners/#findComment-3037976
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
    • I'm not 100% how the BMW racers do it, but I know from other brands like Merc, moving, and changing the coolers is one of the things. Like getting a transcooler out from infront of the radiator to out near a wheel arch. So some of the stuff you've got crammed in the middle front, spread it out and open up where you can in the bar to get more air in to the sides.
    • Small update for the day... Turns out the intercooler and engine coolant hose kits are anything but complete....I probably should have counted better but it only really covers about half the coolant hoses in the car, it really just covers the visible stuff and pretends everything else doesn't exist (turbo water feed and returns and also heat exchanger lines through the 2 pumps and cooler) .In any case, I'm happier to have half reliable hoses than none, but a bit of a disappointment. Anyway...finger click (and 5 hours).....hoses in place, lots of spring clamps replaced with screw clamps, and engine coolant is on the pressure tester for the night.   Incidentally, upsized header tank is an Inifiniti factory option....not sure I'll ever do prod car racing in this but at least it is legal.
    • Just weld it onto the hot pipe. If you want it right after the turbo, put it right after the turbo. Or rip the comp cover off and drill and tap a hole into it.
    • hahaha glad I can rely on you two to go on a spiral at the drop of a problem! Some quick answers....the ducting is excellent top bottom and sides....everything that gets in goes through the coolers (noting the oil cooler redirects it out again, fair call if it is cooling 120o+) and the heat exchanger for the intercooler also has some scoops to pick up more than it's fair share too. I can't see going down the water spray track....no bueno for formal racing and a big risk for long rally days if you run out (plus I'm not clear if it is allowed there either yet).   Frankly, it must be possible to reliably put 400kw through a standard front end, the BMWs do it so I just need to work it out....I'm starting with reducing blockages in the way and adding some coolant capacity with a bigger header tank, flushing rad and making sure it was filled/bled properly (I didn't do the last coolant change); also taken measurements incase next step is a bigger/higher capacity custom radiator
