Looking for an R33 GTS-T no more than $11,000
-Must be manual and not Burgandy or Red in colour.
Please send pics and specs to [email protected]
Will also swap my VL Calais Turbo for R33 GTS-T http://www.calaisturbo.com.au/showthread.p...041#post1284041
Thanks
Edited by BillyMako
https://www.sau.com.au/forums/topic/155627-wanted-r33-gts-t-manual/
im in sydney. could probably work something out in regards to you having to come over here so probz take a little more out of the asking price.
  • 4 weeks later...
'93 R33 GTS-T 178,000k's
5sp
10,000k's on the timing belt, other belts, tensioner/idler bearings, radiator core and water pump.
12,000k's on the rims and tyres (18" AMG ones)
15,000k's on the clutch (just OEM one)
600x300x76 FMIC with 3" piping
32mm 2 row rad (std is 18mm 1 row)
exhaust
dual stage boost controller
oil changed every 5k kms along with filter.
everything runs fine.
However it has some damage and 2 panels are a different colour, the guy before me tried to fix some scratch marks.
Got a quote for $750 to fix it the rear end and re-align it all (no painting factored in though cause it'll be best to fully respray it anyway).
Comes with a new front bar.
And also big dent in rear bar where someone reversed into it or something, should just need another rear, might be able to get the dent taken out, don't know.
And the windscreen has a far crack on the passenger side (passed rego twice like that though)
It's all booked in to be fixed up, but yeah if your handy with a spray gun might be worth it.
looking around the 10k ono mark.
Edited by Rudager
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
