got em for 200 bucks. with some spacers, and some camber magic, they are flush rear, and sunken front. i need like 9 inch wide in the front and ill be good
New wheels to come next week hopefuly.
and aero soon as well hopefully
Edited by yokotas13
https://www.sau.com.au/forums/topic/155635-stagea-build-in-japan/
  • Replies 122
Posted Images
i think it looks like poo
its not low enough, the wheels arent wide enough. the front has Craptastic offsets. rear is too, but i have enough spacer to make it right.
I need Front camber Arms,
and a fender roller
Can someone please change the title to
Japan Stagea Build or something?
just picked up these
150mm 12k springs for hte Silkroad coilovers i have
and 200mm 10k springs
and a Nardi Suede steering wheel to go with my hub and quick release
Edited by yokotas13
But I have a kit and paint in the works
Some 18x9 +24 and 18x10 -4 works in the plans soon also
I get the 4 grand from my car monday, so parts will be ordered
I cant go any lower, im waiting on a fender roller to roll the lips. right now the rear rubs allll the time. and i dont want to lower the front and have a raked effect.
and so you know comparatively how low it is
It will go lower, just gotta roll some stuff, and pound some stuff so the 18s wont rub anything.
i cant wait to start ordering more stuf!!!
heres my exhaust clearance at the moment with it as low as i can go...
thats the muffler and its jammed hard against the underbody and has 60mm clearance from the floor lol
not fun over speedhumps :P
surely your exhuast will be touching the ground Grant if u go lower than u are?
lowered the front another inch
its almost tucking tire
Put some new endless Street sport pads on, still sqeaking. now i have 2 sets of endless pads, one race one street lol
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
