  • Replies 122
Posted Images
if you ever want to sell you side skirts...i want i want... :O mine have shrunk and doesnt join near the back passenger wheel arch any more and i have gone through so many clips and crap that it will just be easier to get another set ;) so ever down the track you want them sold...me me me me me me :)
or for that matter if any one has any side skirts they dont want and want to sell let me know ;)
when i get my kit i will sell you the skirts
So whats thie Dayz thing?
i saw the badge but i dunno what it means
dayz is a aftermarket supplier of goodies for the stagea and quite a few came from the factory with the dayz option kits etc like front and rear bars etc etc etc yours looks like a dayz kit from the front bar
Looking pretty serious now Grant,
Can you still use full steering lock? Looks close, can you take a shot at full lock at some stage, would be interested in seeing the effect.
Cheers
Luke
yes, i can run Full lock
however, it rubs on the top if i turn to fast
i need to roll it a little bit more, and add a tad more camber
its all part of being an innovator....ive only seen two Stageas in a VIP mag
Whats up with the oval "Being Active" sticker on the rear bumper?
My stag that was recently imported to Oz also has one too, a "Prince Tokyo" one to be specific. Is it some ultra cool thing to have in Japan or do they come with it on?
thanks guys
i raised the rear 8 turns, and the front 5 turns
no more rubbing
they hit the coilovers at hard loads on turns in teh rear.
picked up a 3 inch DP today as wwell
yep, as soon as hte 27th comes around
HUGE amount of stuff on order
Cusco 24 and 30mm adjustable sway bars
Front camber arms
Catback
Manifold
z32 mafs
Aero and paint
o2 housing
gauges
and some other stuff
and whatever is left over, ill figure out what to get
as it is thats only like 1600 in parts...i have 1500 left over lol
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
