Stagea Build In Japan!
yokotas13
 Share
a stock rb25 will handle about 350-380hp safely, any more and you will start to lose a ringland or two. :)
depends how you drive it too..
i know of one in WA making ~400rwhp, but its not driven very hard, its barely driven at all.
whereas ive seen other rb25's let go at 330rwhp..
hell, mine died at 300hp, but thats another story..
  • Replies 122
Posted Images
well, right now horribly
when im done and dial in the spring rates to help with body roll in addition to the correct rear sway bar when someone figures out what car to use it from since its obviously not a GTR rear sway (200 dollar lesson)
i think it will handle well once i get everything done.
perhaps import a Whiteline rear swaybar from Sydneykid or Whiteline direct?
very very high quality piece of kit
Im using the whiteline front and rear adjuystable swaybars, whiteline bushes and pineapple rings, Bilstein shocks with height-lowering circlips with standard stagea springs.
very comfy and very very grippy. great suspn package and can be lowered by a fair bit. mine sits a tad high but thats my choice (2metres tall) due to picky police etc.
im going to see what i can do about whiteline from the US and have it shipped here. shouldnt be too much
But as an update
trying to research which rear toe rods are the same. If i had a copy of FAST i could do it myself.
I ordered 8000k dual beam HIDs shoudl be here next week
Bought some puddle lights
bought two 12s and an amp for a temporary setup until i fiberglass my setup and order my real equipment
got an alignmet today, its horribley still toe out in the rear, but since its been adjusted camber wise and as much toe as possible, i have almost 2 inches of clearance between shock and wheel. no more rubbing issues i see, but i ned to roll the rear fenders a tad more.
the kit never got ordered by my "friend" so im debating if i want to order it through someone else, or buy more go fast and handle fast parts.
i have yet to decide
OK
ordered DMAX s14 rear toe arms
THe prosport gauges came in today
the K LIGHT 8000K HIDS came in as well
im still waiting on an AEM UEGO
FPR
coilpack
and a dash pod
OK
FPR
coilpack
and a dash pod
your HIDs are wayyy to blue. your going to get a ticket as soon as an off base cop sees them.
OK
biggg update
bougth a manual swap
Got my greddy oil, flywheel bolts, and pilot bushing in
tranny will be here tomorrow
Garson, headrest pillows, mirror, trim accents, and soem other stuff.
bought NEW Work Emotion XD9 18x9 +20 all around
AEM Uego came in
Prosport gauges came in
FPR came in
HKS twin plate is here
lol
not cheap..... and you'll be parting with it soon enough ?
sad :happy:
what did you do with those 3 spoke wheels? man they look HORN
(Keep the dish, have as much of it as you want, not my style whatsoever, but BEJEEEBUS I love those 3 spoke rims!!)
i sodl em to a friend for 400 US.
im not sellign it anymore, now that i found this stupid 5 speed.
"stupid"...hmmmm
...i take it the manual install is not all wedding cake and honeymoon ??? :happy:
Edited by captinsane
OK
you can drift an automatic Stagea with the front shaft taken out
its crappy becuase its like an open diff or something, but it happens
I make an entire o2 housing back exhaust
i need to redo the part that goes under the subframe becuase i ran out of time and used a prebent section from an R32 exhaust...so ill do that next week or something
im still waiting on my tranny to get here
its boredome
im waiting ot get my new turbo in
once that happens i can order all my pipe for intercooler pipes and exhaust
i want to order it all at once to save on shipping
i found a place for 5.00 a foot for mild steel pipes
will be using a flowmaster muffler with two lone tips out the back
 Share
    • It's so pretty, but I cry at the price (this setup was about $7,500 USD)
    • Yep, I installed it, the sensors, wired everything up so things like the factory blinkers work etc. Fortunately it's not a hard job, just time consuming sorting the wiring out.  If you think this dash is nice, you should check out the actually sexy dashes lol. There would be a fair few people out there that think the IC7 is ugly.  The new and sexy Haltech dash -  https://www.haltech.com/news-events/uc-10dash/ Here is a, I hate having money option from Motec -  https://precisionracing.com.au/product/motec-c1212-display/
    • @Murray_Calavera ohhh.myyyy.gawwwwd 😍 that dash is so much cleaner.  yeah I’m someone who loves older cars, but hate using old tech. A digital dash would always be the way forward. Did you install that yourself?  Thanks for the explanation on oil pressure. I’ll just take it as reference.    Also, your engine light is on 😅😅😅
    • @DraftySquash Yeah... maybe think of those gauges as a super rough estimation of oil pressure and engine temperature.  If you want to see your actual engine temp and oil pressure, you're going to need an aftermarket solution. I'll post a photo of my dash, this is a much neater solution in this day and age. I can't think of any reason why someone would start adding individual gauges.  So grab your dash, then add sensors for all the extra things you want to see.  As for what to expect from oil pressure, super quick run down = cold oil, higher pressure. hot oil, lower pressure. Low revs, lower pressure. higher revs, higher pressure. The values will change based on the viscosity of oil used, the actual temperature of the oil, the type of oil pump used, then more nuanced stuff like clearances in the engine.
    • Should run up to about 6 or so at high revs. But the stock oil pressure gauge is a piece of shit and can't be trusted, so make few to no decisions based on what you see it do.
