  • Replies 122
Posted Images
hmm where you guys afraid of the water getting into the exhaust during a flood? to have an extension like that? :)
i was wonderi'n about that guy now i know why......thats a japenese bong????
drill a hole at the bottom of it problem solved
i got my wheels on today, tried to lower it..and yeah, i fuxored my exhaust up, gotta redo the under bend for the subframe, i didnt notice i had it like 4 inches too low lol...
I just found this thread, thats an awesome build up!! definitely liked the dish on the wagon but I understand changing your mind on rims as I have the same problem! Look forward to seeing more of your progress :)
tuner spec ftw... my opinion anyway - sets it aside from some blinged up honda oddessy which you DO NOT put tuner spec rims on unless ur on drugs
and wtf on that exhaust dude...roflmfao
Edited by captinsane
Grant - I've got a few questions if you wouldn't mind me asking..
- is your stagea RWD or AWD? If it's RWD, did you convert it from a RSFour?
- what offset/size are those Work Emotions?
- is the front bar a DAYZ bar? What rear bar and sideskirts do you have?
Thanks - I appreciate it :)
Ok
It is a FULL dayz compliment
all the parts on the outside are dayz
works are
18x9
+20 all around with a 20mm spacer in teh front
wellll its not too bad
Tranny is out
Ebrake relocated
Pilot bushing in
flywheel on
gotta do the clutch pedal
and the brake pedal
manual harness is in
alternator and starter are wired up
there are a bunch of plugs that arent on the manual harness, so im just gonna see if it works...if not il deal with it then
should be putting in the HKS twin plate, adn tranny tomorrow along with the pedals and clutch master and slave cylinder.
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
