hey mate,
need your postcode to check?
cheers
Its 5082, cheers mate.
I guess I should ask the condition (not that it really matters for that price) but any deep scratches in the pipe or anything that might cause a hole? Rust? And it'll obviously fit a S1 2 door?
Edited by harvesteros
