How Do You Change The Brake Pads?
IMPORTD
 Share
put some r33 gtst or r32 gtr calipers and rotors on it, its definately needed if u do any spirited driving as the stock brakes are horrible and with automatic u cant use the gears to slow u down either :P
Brad
Any indication of how much this would cost to do?
Cheers, Al
here in japan i can get the calipers for around 140 for hte front
and rotors for around 300 new
Dude, don't forget that in Japan you probably have an abundance of places to get the parts from, with a lot more choice than us here in Australia, and I'm guessing you're quoting US Dollars, not Australian Dollars, so the prices are somewhat irrelevant to us...
Oh, and Kylie, I thought the front pads were DB1250's? Might have to take them down for cross-referencing when the time comes to change mine... Like Leetom said, if you can't take one off and take it with you when you go to buy some, take a piece of paper and trace around one of the pads and take that to the parts shop to check against.
Hey Al im unsure on costs sorry, i know the 32 gtr and 33 gtst calipers (both the same) are fairly cheap, around $400 for a front pair as a rough estimate and slotted 297mm rotors from DBA would be around $400 for the pair as well. i bought the 34 brembos and 330mm rotors so i dont know about the other calipers/rotors except that they definately bolt on :P
good luck and catch u guys on the cruise tommorow :)
I did mine recently and found that I had to crack the bleed plug to get the piston to move back so I could fit the new pads.
The other cars I have changed pads on did not need this, the fluid just back flowed into the reservior.
Other than that, it was an easy job, saved me about NZ$200. At my last service, they said that they needed doing, and they would do it for NZ$140 + skimming. My front discs did not need skimming so I did it myself.
im actually trying to see if i can mail stuff to you guys so i can pass on the japan price deals!
Hey Kylie
whenever you are changing pads and compressing the brake pistons in, just remember to get someone to watch the fluid level in the resevoir, as if it is full up and you do both without looking it can overflow. The level will rise as the calipers are pushed in. Brake fluid is not good for your engine bay!
Also you can use the tiptronic (to change down) in the S2 to slow the car, or in an S1 change down, into 2. It does help a bit.
So, does anyone have a complete set of Stagea calipers that they want to get rid of? I am looking for the 2 piston fronts and the rears that take the DB1144 pads (though will consider others). I am in Canberra, if that makes a difference.
Cheers,
Matt
Edited by Matty T
Not sure what you got, nor have I changed my pads before on my S2 Staj. But maybe the ABS has something to do with the above problems.??
I forgot to take pictures
I'm sorry, but if you want to remain a bonafide member of this forum you will have to go back and take pictures...and we dont care if it is raining...or snowing...pics or ban!!
 Share
    • It's so pretty, but I cry at the price (this setup was about $7,500 USD)
    • Yep, I installed it, the sensors, wired everything up so things like the factory blinkers work etc. Fortunately it's not a hard job, just time consuming sorting the wiring out.  If you think this dash is nice, you should check out the actually sexy dashes lol. There would be a fair few people out there that think the IC7 is ugly.  The new and sexy Haltech dash -  https://www.haltech.com/news-events/uc-10dash/ Here is a, I hate having money option from Motec -  https://precisionracing.com.au/product/motec-c1212-display/
    • @Murray_Calavera ohhh.myyyy.gawwwwd 😍 that dash is so much cleaner.  yeah I’m someone who loves older cars, but hate using old tech. A digital dash would always be the way forward. Did you install that yourself?  Thanks for the explanation on oil pressure. I’ll just take it as reference.    Also, your engine light is on 😅😅😅
    • @DraftySquash Yeah... maybe think of those gauges as a super rough estimation of oil pressure and engine temperature.  If you want to see your actual engine temp and oil pressure, you're going to need an aftermarket solution. I'll post a photo of my dash, this is a much neater solution in this day and age. I can't think of any reason why someone would start adding individual gauges.  So grab your dash, then add sensors for all the extra things you want to see.  As for what to expect from oil pressure, super quick run down = cold oil, higher pressure. hot oil, lower pressure. Low revs, lower pressure. higher revs, higher pressure. The values will change based on the viscosity of oil used, the actual temperature of the oil, the type of oil pump used, then more nuanced stuff like clearances in the engine.
    • Should run up to about 6 or so at high revs. But the stock oil pressure gauge is a piece of shit and can't be trusted, so make few to no decisions based on what you see it do.
