How Do You Change The Brake Pads?
IMPORTD
 Share
put some r33 gtst or r32 gtr calipers and rotors on it, its definately needed if u do any spirited driving as the stock brakes are horrible and with automatic u cant use the gears to slow u down either :P
Brad
Any indication of how much this would cost to do?
Cheers, Al
here in japan i can get the calipers for around 140 for hte front
and rotors for around 300 new
Dude, don't forget that in Japan you probably have an abundance of places to get the parts from, with a lot more choice than us here in Australia, and I'm guessing you're quoting US Dollars, not Australian Dollars, so the prices are somewhat irrelevant to us...
Oh, and Kylie, I thought the front pads were DB1250's? Might have to take them down for cross-referencing when the time comes to change mine... Like Leetom said, if you can't take one off and take it with you when you go to buy some, take a piece of paper and trace around one of the pads and take that to the parts shop to check against.
Hey Al im unsure on costs sorry, i know the 32 gtr and 33 gtst calipers (both the same) are fairly cheap, around $400 for a front pair as a rough estimate and slotted 297mm rotors from DBA would be around $400 for the pair as well. i bought the 34 brembos and 330mm rotors so i dont know about the other calipers/rotors except that they definately bolt on :P
good luck and catch u guys on the cruise tommorow :)
I did mine recently and found that I had to crack the bleed plug to get the piston to move back so I could fit the new pads.
The other cars I have changed pads on did not need this, the fluid just back flowed into the reservior.
Other than that, it was an easy job, saved me about NZ$200. At my last service, they said that they needed doing, and they would do it for NZ$140 + skimming. My front discs did not need skimming so I did it myself.
im actually trying to see if i can mail stuff to you guys so i can pass on the japan price deals!
Hey Kylie
whenever you are changing pads and compressing the brake pistons in, just remember to get someone to watch the fluid level in the resevoir, as if it is full up and you do both without looking it can overflow. The level will rise as the calipers are pushed in. Brake fluid is not good for your engine bay!
Also you can use the tiptronic (to change down) in the S2 to slow the car, or in an S1 change down, into 2. It does help a bit.
So, does anyone have a complete set of Stagea calipers that they want to get rid of? I am looking for the 2 piston fronts and the rears that take the DB1144 pads (though will consider others). I am in Canberra, if that makes a difference.
Cheers,
Matt
Edited by Matty T
Not sure what you got, nor have I changed my pads before on my S2 Staj. But maybe the ABS has something to do with the above problems.??
I forgot to take pictures
I'm sorry, but if you want to remain a bonafide member of this forum you will have to go back and take pictures...and we dont care if it is raining...or snowing...pics or ban!!
 Share
    • Hey guys any recommendations for fitment for a stock 94 GTR R32  Want to order work meister s1 3p and would like a nice looking flush fitment. Plan to get MCA coilovers to set ride height etc. Just confused on offset, brake clearance etc.  Never purchased after market wheels so I'm a bit concerned since it's a long wait to order and I don't want to order the wrong specs.
    • Update: Done: -Running on 6 cylinders, one injector was gummed up. I made an injector tapper, bit of Teflon on the end of a metal rod.  That fixed the injector. Need to replace one injector plug, the fastener is broken. -Coolant bleed -Fixed 4WD warning light, bleed 4wd system -Fixed electrical problems: alarm, brake lights, various broken plugs  -Got all the parts ready to connect head drain. Head drain is fitted with a blocker atm Todo: -Fuel pump dead, Been cleaning out the tank, had a lot of tobacco looking stuff, think its OEM foam. Got a Walbro 460 to put in. Probably going to add a relay to give the pump a solid 13volts. Replacing all the fuel hoses, in tank etc. -Front drive shafts still not back on. Waiting on parts. Would like to buy some new ones, but probably going to patch these up for now -Replacing gas struts on back door. Waiting to be returned -Headlights need a polish/repair -Going to touch up the paint a little. -Clean up the interior -Connect up heater plumbing -Cosmetic stuff, powder coat replace rusty parts, replace rusty bolts, wiper blades, silicon missing rubber -A million other things
    • Don't do this unless it never gets hot where you are.
    • Upgrade time. Been a long time coming, but I was able to get my GTR to a reputable builder in the States. List of upgrade parts below: RB30 (Sourced from Australia) PRP RB30 timing belt kit with all options Nitto pistons Nitto I beam rods Nitto oil pump King engine bearings New RB26 Head (Grabbed during Heritage run) Kelford 272 cams mild lift Supertech intake and exhaust valves over sized Nitto Head gasket Greddy Oil Pan Sump GKtech fan blade and adapter Koyo Radiator Borg Warner S362 SXE 6boost turbo manifold T4 divided  Turbosmart wastegate Pro-gate 50 lite ID1340x injectors Radium external surge tank Walbro 450 fuel pumps x2   All Parts in hand and awaiting my turn in line at the shop!
