Hi guys,
Can anyone help me with the electrical side of how to wire a ICE thermo switch. Especially where it is marked C and the number 2 on the thermo switch terminals. There are only two terminals on the thermo switch. Btw the car is a R34.
Does iginition or accessories wire actually go to the thermo switch on C?, what would be a good example to use in the engine bay eg: starter motor etc?
I tried iginition on the C on the thermo switch and it didnt seem to work.
The information provided in the wiring guide is just confusing. Ive supplied a photo which i drew, but what stumps me is this part of the information.
It states Terminal 86: Supplies 12-volt positive power from:
Air conditioning clutch.
This is what excalty is drawn on the diagram provided in the wiring guidelines.
Can someone please help me asap, as this is the last thing i have to do to get the car back on the road.
Cheers! :P
Edited by DRFT31
If you use the ac clutch power the thermo will only switch on when the AC is on. As you are wiring it in with a thermo switch i assume you want it to regulate engine temp, rather than just act as an ac fan. There are a heap of ignition sources in the fuse box, anything that turns on with ignition like fuel pump for example will have to have either a triggered positive or negative wire running to a pin.
The diagram up top is correct as far as i can see. The thermo switch is the trigger for the relay so it's inline between the power source and the relay. 85 is earthed so when the temp gets up to the set level of the switch it will trip the relay and provide power to pin 87 turning on the fan.
Easy test is to short pin 86 straight to the battery and see if the fan starts. If it doesn't turn on your problem is something else.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
    • Shit. Starting to look like a car again.
