ok, well, 2 things - Do they come with some sort of warranty, and would you take $430 for them?
How long were they "tested" for?
Were they only bought to see if your current packs were stuffed?
Oh, and will these fit, meaning are you able to put the Engine Center cover back on? (So it looks stock) Thanks.
Sorry about all of the questions.
Edited by The Mafia
https://www.sau.com.au/forums/topic/155656-sold/#findComment-2897009
Only warranty I can give you is that they work, if you buy them and I put them in your car they will work I can guarantee that . As with all elecronic parts you can stuff them up if you dont fit them correct, nobody will warranty that .
The price is $490 , no I wont take $430 , don't forget they are like new , if I didnt tell you they have been used you wouldn't know.
Very short period of time to rectify a fault on a car that turned out to be the CAS. ( not my car)
They are exacly the same as the stockers , so you can put the cover back on. Do you have a series II GTST? If yes they are suitable , If you have different car to your avatar then do a search to see if they are suitable using the part number in the pic. I know they are suitable for a series II GTST and R34 GTR.
https://www.sau.com.au/forums/topic/155656-sold/#findComment-2897464
And I am pretty sure that's even more warranty than you'll get from Splitfire themselves, because when I got mine a couple of years ago the documentation specifically said that the warranty is only valid in Japan. Unless they've changed their warranty policy recently. $490 is a bargain, I would buy them in an instant if I was after some.
https://www.sau.com.au/forums/topic/155656-sold/#findComment-2902318
Thanks for the comments jimX, i think they are well priced cionsidering they retail for $795.00 and they are almost new. If I can't get that I'll just keep them for spares for my car..
phatboi2010, They wont suit Rb20 mate, you will need DIS-001 for your car and GTRS up to series III R33.
These will suit RB25 from 95 on and RB26 R34 only.
https://www.sau.com.au/forums/topic/155656-sold/#findComment-2902417
PM sent
P.M send , please get back to me ASAP , the latest by tonight to confirm that you want them. If I don't hear from you by tonight they will be offered to the next person that wants them ..
https://www.sau.com.au/forums/topic/155656-sold/#findComment-2902826
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
