  • Replies 44
Posted Images
T04FTR ---- in terms of the response, its pretty responsive compare to my RB20 with GT3040R. with my GT3040R in my RB20DEt i was getting full boost at 4600rpm but ut was pretty slugish. BUT with my new setup boost kicks in at 5600RPM but i can feel it pulling before it hits full boost.
i took the car to WSID in november last year just to test it out how it goes with street tires, i tried it at 16 psi ( my max boost setting) and the car was going sideways all the way in 4th gear ( from 2nd gear i put my foot down) and i finished the 400m in nutural :) that day i manged 13.0 @ 116 mph at 10psi.
Also as i mentioned befor my Exhaust housing size is 1.16 which is pretty big compare to ordinary T04Zs. Coz my turbo has been customly built for my application.
Its pretty pointless to darg withought my Mickies.
Cheers :huh:
cooool thats just what i wanted to know. thanks mate :)
  • 3 weeks later...
  • 5 months later...
does a fully rebuilt/balanced rb25/30 Neo have the power band to do these turbos justice? Im interested in the ones slides sell with a 1.01 a/r? I would think max rpm would be 7500rpm. Would i have any clearance issues aswell?
cheers
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
