my local shop was trying to fit my Xenons on my car and it turns out the "ballist" is stuffed.
he explains that there is 12V going to the ballist but nothing cummin out.
now this is only one of the ballists. but on futher inspection all the wires leading from the ballist to the globe were exposed.
im lead to believe the wires could be the reason why its stuffed not the ballist. can anyone recommend somone for a 2nd oppionion?
South East Suburbs if possible
https://www.sau.com.au/forums/topic/155686-local-xenon-fitter/
1) these kits are easy to install... i have absolutely ZERO knowledge of the workings of cars (a car fan yes, but mechanic i am not) and was able to get mine in (plug and play once you get good access to the headlights. I actually took my front bar off, not sure if that was completely necessary)
2) after-market kits are 95% poorly made, unless you get some decent brand like Philips, maybe GE and some korean ones are quite good. If you bought one of those $250 kits, good chance it's a crapper (and some can be quite dangerous in terms of engine bay fires)
3) in the end, the light will be shit from these after market kits in R34 Xenon assemblies. Fact of life. Replace with OEM parts or do a projector retro-fit, = $$$$$$$$$$$$$$$$$$$$$$$$
lol i no i no R34 after market Xenons are shiet but what else can i do...use halogens?? the thing is i know its easi to fit but the exisiting wires in the headunit are exposed.......so yeh....im actually thinkin of buying phillips now........
i got a Kaixen kit, korean made. Something about Phillips and Kaixen bulbs being the only type of something-a-rather, in other words, a decent quality one.
got pics of your kit? you should have 2 ballasts... one for each headlight.
ive wired everything up....but for some reason theres 12V going to the ballist but nothing cumming out of it. my conclusion and 2 other macanics have said that the ballist is screwed....but i wanted to take it to a auto tec to make sure.
2 ballist 2 globes wires....everythings in the box.
how much did u pay for ur Kaixen SS8 ?
i can't remember exactly. If you go check the threads that BATMBL has started in the for sale section, i bought the Kaixen kit off him. Maybe just search 'kaixen' but just choose the the 'for sale' forum
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
